Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] A passive two-step control fluid damping device for seismic protection of structures
[Request] A passive two-step control fluid damping device for seismic protection of structures
 3fan
Romania
User ID: 29614
Threads: 161
Likes: 7,359 in 1,207 posts
Given Likes: 5546
09-27-2011, 01:30 PM (This post was last modified: 09-27-2011, 01:32 PM by 3fan.)
A passive two-step control fluid damping device for seismic protection of structures PhD Thesis
Author: Wang, Hongbo, Ph.D | Format: PDF | Publisher: STATE UNIVERSITY OF NEW YORK AT BUFFALO | Year: 2008 | pages: 215
Abstract:
This dissertation describes the development of a new passive two-step control damping (PTCD) device for the seismic protection of structures. The new device is a passive system that acts as a semi-active system by delivering two-step variable damping forces. It can be applied directly to structures in series with a linearly elastic brace, or as part of a seismic isolation system by providing an added fail-safe function when the displacement of the structure becomes excessively large. The PTCD device is simple, cheap and reliable, because its operation does not need the external power, sensors, computers or special algorithms that are part of a standard active or semi-active system.
Based on the operating principles of mechanical valves, a prototype PTCD device has been manufactured and tested under both sinusoidal waves and earthquake ground motions in the laboratory. Test results show that the PTCD device consistently provides the analytically predicted two-step variable damping functions. The analytical model was further simplified to allow direct calculation of the two-step force-displacement relationship to encourage use of the PTCD device in engineering practice.
Using a simplified approach, parametric studies were conducted on the seismic responses of a single-degree-of-freedom (SDOF) system with the PTCD device installed and subjected to the MCEER west coast ground motions. When compared to corresponding systems installed with conventional passive dampers, the proposed PTCD device provided superior performance for earthquakes of different intensities. This was illustrated by the significantly reduced displacement responses under earthquakes with near-fault characteristics when two-step damping is provided, and a lower level acceleration response under low and moderate earthquakes.
To illustrate the effectiveness of this device in limiting extra large isolator displacement, a base isolation system was experimentally studied. This isolation system consisted of a roller isolation bearing (RIB), and the proposed PTCD device. Shake table tests were performed on a rigid superstructure equipped with the base isolation system. Experimental results showed good agreement with the numerically predicted results. Both the analytical and experimental results illustrated that the PTCD device effectively reduced bearing displacements and provided better performance for isolated structures.
Thanks in advance,
3fan
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
09-27-2011, 04:57 PM (This post was last modified: 09-27-2011, 05:04 PM by ssobhan.)
Author: Wang, Hongbo | Size: 9.4 MB | Format: PDF | Year: 2008 | pages: 215
[Image: 36910160842836930176.jpg]
[-] The following 4 users Like ssobhan's post:4 users Like ssobhan's post
  • jcbv, 3fan, Dell_Brett, tluc
 3fan
Romania
User ID: 29614
Threads: 161
Given Likes: 5546
09-27-2011, 05:33 PM
[-] The following 2 users Like 3fan's post:2 users Like 3fan's post
  • Dell_Brett, ting tsai huang
  [REQUEST] Building Control with Passive Dampers sola4466 2 2,000 03-21-2014, 08:15 AM
  [REQUEST] Response Control and Seismic Isolation of Buildings haydaroglu 1 1,573 07-19-2013, 09:49 AM
Last Post: fred2010
  [REQUEST] Seismic Response Analysis of Large Liquid Storage Tank Considering Fluid-Structure In ssobhan 1 1,604 06-19-2013, 10:56 AM
Last Post: mybest
  [REQUEST] Seismic Control Systems - Design and Performance Assessment ibmarin 0 1,448 11-06-2012, 12:49 AM
Last Post: ibmarin
  [REQUEST] Building Control with Passive Dampers: Optimal Performance-based Design for Earthquak sola4466 0 1,507 10-06-2012, 02:52 PM
Last Post: sola4466
  [REQUEST] Effect of non-proportional damping on seismic isolation 2002 picci4 1 1,591 08-30-2012, 01:48 PM
  [REQUEST] Control of Cracking in Concrete Structures - ACI 224R-01 pacman 3 2,801 06-26-2012, 11:48 AM
