Civil Engineering Association Software Software Product Non Engineering Software AttributeMagic Pro v3.3
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,705 in 1,304 posts
Given Likes: 4618
09-16-2011, 12:15 PM (This post was last modified: 09-16-2011, 12:27 PM by lisine.)
[Image: 68455579444281621275.jpg]
Utility can change file date/time stamps created, modified, accessed. You can set new date-time, relatively change date or time, copy one date-time stamp to another (created date=modified date), change the date but not touch the time, shift date from AM to PM and vice-versa, sequentially change date-time with user specified time step
With our utility you can set file date in a sequence in order to present files in the right order. Utility is for Windows only.
Renaming files and folders
AttributeMagic Pro can mass rename files and folders (including images, document files, etc.) You can add date-time stamps to the name of file or folder, add EXIF tags to the file name, convert file/folder name and extension to the upper or lower case, add file and folder size to it's name. Also you can replace or remove the part of file name or any string meta tag.
Changing attributes of files and folders
With our utility you can modify following file system attributes: hidden, read-only, system, archived, offline. Utility can set, reset, invert and copy one attribute to another.
Modifying properties of MS Office documents
Utility can modify metadata stored with MS Excel, MS PowerPoint and MS Word documents. It can change or clear following document properties: title, subject, keywords, template, author, last author, revision number. Date-time stamps of MS Office documents can be changed too: document created, last saved, last printed. Using AttributeMagic Pro you can clear (scrub) all metadata or only particular element.
Changing picture date and JPEG-EXIF metadata
With AttributeMagic Pro you can change EXIF date-time stamps: date picture taken, original, digitized. Also utility can change text fields in the EXIF data: make, model, description, artist. AttributeMagic can manipulate EXIF date-time stamps (mask, shift, AM to PM etc.) you can copy EXIF date-time stamp to the file date-time stamps: file created date=picture taken. An EXIF data can be added to non-EXIF JPEG files. Manipulation of EXIF Orientation tag is possible.
Usability
soring in natural order for file names and string metadata
preview result window helps you inspect changes
utility can process one file, folder or a group of files, folders, subfolders
recursive operations: process whole directory tree (or certain branch)
command line mode
print, save, export folder(directory) contents
powerful custom filters and templates to selectively stamp necessary files or folders
error reporting and logging
[Image: homepage.png]
[Image: comments.png]
Application+medicine inside
[-] The following 6 users Like lisine's post:6 users Like lisine's post
  • slowet, DamaD, oanm2000, kvtasp, Clouseau, ykhackhack
 kvtasp
User ID: 7690
Threads: 69
Likes: 2,028 in 379 posts
Given Likes: 791
11-02-2011, 02:46 PM
Mirror Link for POST#1
[-] The following 2 users Like kvtasp's post:2 users Like kvtasp's post
  • Clouseau, ykhackhack
