Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] EN 1452 & EN 1401
[Request] EN 1452 & EN 1401
 rigid_joint
Senior Member
Jamaica
User ID: 6110
Threads: 16
Likes: 333 in 122 posts
Given Likes: 244
Points:8,861 EP
09-08-2011, 02:15 AM
i' m looking for these two codes:
EN 1401: Plastics piping systems for non-pressure underground drainage and sewerage. Unplasticized poly(vinylchloride) (PVC-U). Specifications for pipes, fittings and the system
EN 1452: Plastics piping systems for water supply. Unplasticized poly(vinyl chloride) (PVC-U). Valves and ancillary equipment
i would be grateful if any member shared these
 peixoto
Portugal
User ID: 6963
Threads: 51
Likes: 968 in 114 posts
Points:6,960 EP
09-08-2011, 07:34 AM (This post was last modified: 09-08-2011, 08:13 AM by peixoto.)
BS EN 1401-1:1998
Author: BSI | Size: 0.335 MB | Format: PDF | Publisher: BSI | Year: 1998 | pages: 36 | ISBN: 0 580 29709 8
[Image: 47440402340384832049.jpg]
Standard Number: BS EN 1401-1:1998
Title: Plastics piping systems for non-pressure underground drainage and sewerage. Unplasticized poly(vinylchloride) (PVC-U). Specifications for pipes, fittings and the system
Status: Revised, Withdrawn
Withdrawn Date: 31 July 2009
Very important----->Replaced By
BS EN 1401-1:2009
International Relationships: EN 1401-1:1998 Identical
Descriptors
Pipes, Pipe fittings, Unplasticized polyvinyl chloride, Polyvinyl chloride, Plastics, Drainage, Drainpipes, Sewers, Underground, Plastic pipelines, Water supply and waste systems (buildings), Size, Dimensions, Dimensional tolerances, Diameter, Thickness, Length, Shape, Colour, Performance, Marking, Designations, Spigot-and-socket joints, Pipe couplings, Impact strength, Stiffness, Softening point, Deformation, Thermal resistance, Sealing rings, Pressure testing, Leak tests, Chemical-resistance tests, Testing conditions, Recycling
ICS
23.040.20 (Plastics pipes)
91.140.80 (Drainage systems)
93.030 (External sewage systems)
BS EN 1452-4:1999
Author: BSI | Size: 1.04 MB | Format: PDF | Publisher: BSI | Year: 2000 | pages: 32 | ISBN: 978 0 580 69345 8
[Image: 38758093039988384615.jpg]
Standard Number
BS EN 1452-4:1999
Title
Plastics piping systems for water supply. Unplasticized poly(vinyl chloride) (PVC-U) Ð. Valves and ancillary equipment
Status
Superseded, Withdrawn
Withdrawn Date
31 January 2010
BS EN ISO 1452-4:2009
EN 1452-4:1999 Identical
Descriptors
Plastics, Polymers, Pipework systems, Plastic pipelines, Water, Pipes, Water supply engineering, Water supply (buildings), Unplasticized polyvinyl chloride, Polyvinyl chloride, Valves, Water supply, Water mains, Underground, External, Internal, Buildings, Pressure, Temperature, Cold-water supply systems, Potable water, Saddle joints, Elastomers, Sealing rings, Adhesive-bonded joints, Spigot-and-socket joints, Flanged fittings, Flanges, Dimensions, Gate valves, Butterfly valves, Plug valves, Diaphragm valves, Mechanical properties of materials, Performance testing, Thermal testing, Hydraulic tests, Marking
ICS
23.040.01 (Pipeline components and pipelines in general)
23.060.01 (Valves in general)
91.140.60 (Water supply systems)
This is not the most recent norms, but maybee they can help anyway. Regards
[-] The following 6 users Like peixoto's post:6 users Like peixoto's post
  • kowheng, Grunf, Dell_Brett, Jackass, malc, rigid_joint
