Civil Engineering Association eBooks Traffic Engineering NCHRP - R673 A Manual for Design of Hot Mix Asphalt with Commentary
 cace-01
User ID: 15651
Threads: 440
Likes: 10,522 in 867 posts
Given Likes: 7468
06-30-2011, 08:16 AM (This post was last modified: 09-14-2014, 04:26 PM by usman.)
Author: NCHRP | Size: ~7 MB | Format: PDF | Publisher: TRB, National Academy of Sciences | Year: 2011 | pages: 285 | ISBN: N/A
[Image: 33259991011423888665.jpeg]
This Final Report incorporates the many advances in materials characterization and hot-mix asphalt (HMA) mix design technology developed since the conclusion of the Strategic Highway Research Program (SHRP).
Contents
1 Chapter 1 Introduction
4 Chapter 2 Background
4 Materials Used in Making Asphalt Concrete
5 Asphalt Concrete Pavements
7 How Asphalt Concrete Pavements Fail
10 Asphalt Concrete Mixtures
12 HMA Mix Design Methods
15 Chapter 3 Asphalt Binders
17 Performance Grading of Asphalt Binders—Overview
17 Performance Grading—Test Methods
22 Performance Grading—Specification
24 Critical Temperatures, Specification Values, and Reliability
26 Practical Selection of PG Binder Grades for HMA Mix Design
28 Chapter 4 Aggregates
28 Aggregate Particle Size Distribution
33 Aggregate Specific Gravity and Absorption
38 Aggregate Specification Properties
43 Source Aggregate Properties
46 Chapter 5 Mixture Volumetric Composition
46 Composition Factors
53 Mixture-Specific Gravity
56 Volumetric Analysis
65 Chapter 6 Evaluating the Performance of Asphalt Concrete Mixtures
66 Mixture Composition and Performance
71 Laboratory Testing
82 Performance Predictions Using the AASHTO Mechanistic-Empirical Pavement Design Guide (MEPDG)
91 Chapter 7 Selection of Asphalt Concrete Mix Type
91 Pavement Structure and Construction
95 Important Factors in Mix Selection
98 Recommended Mix Types
101 Chapter 8 Design of Dense-Graded HMA Mixtures
101 Other Mix Design Methods
106 Overview of Design Method
107 Step 1. Gather Information
108 Step 2. Select Asphalt Binder
111 Step 3. Determine Compaction Level
111 Step 4. Select Nominal Maximum Aggregate Size
112 Step 5. Determine Target VMA and Design Air Void Content
114 Step 6. Calculate Target Binder Content
114 Step 7. Calculate Aggregate Content
114 Step 8. Proportion Aggregates for Trial Mixtures
124 Step 9. Calculate Trial Mix Proportions by Weight and Check Dust/Binder Ratio
128 Step 10. Evaluate and Refine Trial Mixtures
145 Step 11. Compile Mix Design Report
148 Chapter 9 Reclaimed Asphalt Pavement
148 General Mixture Design Considerations for RAP
150 Overview of the Mixture Design Process with RAP
151 A Note on General Methods of Handling RAP
151 Using HMA Tools to Design HMA Mixes with RAP
152 RAP Sampling
153 Blending and Variability
161 RAP Aggregate Properties
164 RAP Binder Properties
170 Handling RAP Materials in the Laboratory
174 Chapter 10 Design of Gap-Graded HMA Mixtures
174 Overview of GGHMA Mix Design Procedure
176 Step 1—Materials Selection
179 Step 2—Trial Gradations
188 Step 3—Selection of Optimum Gradation
189 Step 4—Refine Design Asphalt Binder Content
189 Step 5—Conduct Performance Testing
191 Trouble Shooting GGHMA Mix Designs
194 Chapter 11 Design of Open-Graded Mixtures
195 Overview of PFC Mix Design Procedure
195 Step 1—OGFC Materials Selection
198 Step 2—Trial Gradations
203 Step 3—Selection of Optimum Gradation
203 Step 4—Selection of Optimum Asphalt Binder Content
205 Step 5—Moisture Susceptibility
205 Trouble Shooting PFC Mix Designs
207 Chapter 12 Field Adjustments and Quality Assurance of HMA Mixtures
207 Adjusting Laboratory HMA Mix Designs for Plant Production
211 Quality Control of HMA
225 Commentary to the Mix Design Manual for Hot Mix Asphalt
226 Chapter 1 Introduction
227 Chapter 2 Background
228 Chapter 3 Asphalt Binders
229 Chapter 4 Aggregates
231 Chapter 5 Mixture Volumetric Composition
232 Chapter 6 Evaluating the Performance of Asphalt Concrete Mixtures
240 Chapter 7 Selection of Asphalt Concrete Mix Type
241 Chapter 8 Design of Dense-Graded HMA Mixtures
253 Chapter 9 Reclaimed Asphalt Pavement
265 Chapter 10 Design of Gap-Graded HMA Mixtures
266 Chapter 11 Design of Open-Graded Mixtures
267 Chapter 12 Field Adjustments and Quality Assurance of HMA Mixtures
271 References
[-] The following 8 users Like cace-01's post:8 users Like cace-01's post
  • kowheng, blaze, utan, Evandrojr, cigutierrezg, shaqee, Ivan_1980, Jackass
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-23-2012, 09:56 AM
Author: Advanced Asphalt Technologies, LLC | Size: 6.81 MB | Format: PDF | Quality: Original preprint | Publisher: Transportation Research Board | Year: 2011 | pages: 283 | ISBN: 9780309155649
[Image: 61583214357568856425.png]
This report presents a mix design manual for hot mix asphalt (HMA) that incorporates the many advances in materials characterization and mix design technology developed since the conclusion of the Strategic Highway Research Program (SHRP). The manual also includes a mix design method for warm mix asphalt (WMA). The report will be of immediate interest to materials engineers in state highway agencies and industry. The manual's key features are (1) a single mix design method applicable to dense-graded, open-graded, and gap-graded HMA and WMA; (2) the application of a range of performance tests and criteria to estimate potential permanent deformation, fatigue cracking, and low-temperature cracking behavior of HMA and WMA mix designs; (3) integration of mix and structural design through the use of the Mechanistic-Empirical Pavement Design Guide (MEPDG) software to validate HMA performance for specific combinations of pavement structure, climate, and traffic; and (4) the extensive use of examples to illustrate all facets of the mix design method. Detailed technical discussion to support the methodologies and processes included in the manual are presented in the commentary following the final chapter.
[-] The following 8 users Like mahyarov's post:8 users Like mahyarov's post
  • shadabg, kowheng, duazo2009, Mohammad6299, cace-01, oanm2000, mbakr, toa011
  MS-2 Asphalt Mix Design Methods - 7th Edition febo927 0 1,841 06-26-2018, 11:59 AM
Last Post: febo927
  Asphalt Materials and Mix Design Manual preceptor 4 4,232 03-16-2014, 02:49 AM
Last Post: Mohammad6299
  Asphalt Emulsion Technology: Review of Asphalt Emulsion Residue Procedures mahyarov 0 1,714 10-27-2012, 08:35 AM
Last Post: mahyarov
  NCHRP - R612 Safe and Aesthetic Design of Urban Roadside Treatments mahyarov 0 1,385 10-23-2012, 06:22 PM
Last Post: mahyarov
  NCHRP - R648 Mixing and Compaction Temperatures of Asphalt Binders in Hot-Mix Asphalt mahyarov 0 1,720 10-23-2012, 04:25 PM
Last Post: mahyarov
  Mix Design Practices for Warm Mix Asphalt mahyarov 0 1,339 10-23-2012, 10:08 AM
Last Post: mahyarov
  NCHRP R715 - Highway Safety Manual Training Materials mahyarov 1 1,757 10-23-2012, 06:48 AM
Last Post: mahyarov
