Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Steel design optimization Thesis
Away  mastermind
Egypt
User ID: 11465
Threads: 22
Likes: 392 in 45 posts
Given Likes: 327
06-10-2011, 07:47 AM (This post was last modified: 06-10-2011, 05:55 PM by oanm2000.)
Size: 3 MB | Format: RAR
Organisation of the thesis
The thesis consists of ten chapters and three appendices. These can be summarised as follows:
Chapter 1 provides an introduction, raising the problems associated with the analysis and design of steel frame structures. The main features of a design optimization problem are then discussed. The literature review of the design optimisation of steel frameworks is also demonstrated. Finally, the aim of research and overview of the thesis are presented.
Chapter 2 describes in details the design procedure as required by the British Codes of Practice. The chapter ends with describing methods used, in the present study, to represent the charts of the effective length factor of column in sway and non-sway frames into a computer code. Here, analytical solutions are obtained using regression analysis based on Statistical Package for Social Sciences (SPSS) and genetic programming methodology.
Chapter 3 starts with studying the stability concept, historical background about the stability problem of steel frames. It then discusses the methods of analysis, which are used for the determination of the effective buckling length of columns in sway and nonsway frameworks. A FORTRAN code based on the direct method is developed and verified using results from the literature and the finite element package (ANSYS).
In Chapter 4, the stability concept of steel frame structures has been applied where the general forms of the critical buckling load of five frameworks are obtained using the direct method of analysis. The finite element package (ANSYS) is also used to verify the results obtained from these forms. Comparisons have been made between the effective buckling length factor calculated by the more accurate analysis (direct method or finite element method) and that determined by the approach presented by BS 5950.
Finally, four questions are raised, and the answers will be given in the following chapters.
Chapter 5 introduces main features and formulation of the design optimisation problem. It also discusses the most frequently used methods of design optimization. Here, the concept of genetic algorithm is described in detail.
Chapter 6 describes the developed GA, new implementations, tuning of genetic algorithm parameters and comprehensive tests are presented. Different crossover operators are implemented and also tested. Comparisons between results obtained by the developed algorithm and those described in the literature or those obtained when
using the ANSYS optimization methodology are also presented.
Chapter 7 is concerned with assessing the potential of the developed genetic algorithm to the treatment of complicated structural problems. Here, the maximum ratio between the effective buckling length factor determined by the approach presented by BS 5950 and the calculated by using the finite element analysis is investigated. Three problems are formulated and solutions are obtained for different examples.
Chapter 8 presents a genetic algorithm based technique for the design optimization of multi-storey steel frame structures according to BS 5950. In this chapter, it has been proven that the developed genetic algorithm linked to design rules to B S5950 can successfully be incorporated in design optimization in which the structural members are required to be selected from the available catalogue and the design should satisfy a practical design situation. In the formulation of the optimization problem, the objective function is the total weight of the structure and constraints are imposed on the design
criteria as required by the British codes of practice (BS 5950 and BS 6399). The design variables are selected from a catalogue (British Standard BS 4). In addition, to study the effect of the accuracy of determining the effective buckling length on the optimization process and the obtained optimum designs, three approaches for determining its value are considered. Finally, In order to verify the results achieved by applying the developed Fortran code for design optimization, the CSC (1998) software is used.
Chapter 9 extends the study of chapter 8 to the discrete optimum design of threedimensional (3D) steel frame structures using the modified genetic algorithm (GA). Following the design procedure of steel structures to BS 5950, the minimum weight design of 3D steel frame structures is presented where the most unfavourable loading cases are considered. The CSC (1998) software is also used to verify results.
Chapter 10 shows the main achievements, conclusions followed by recommendations for several promising area of further work.
[-] The following 32 users Like mastermind's post:32 users Like mastermind's post
  • blaze, Jackass, Dell_Brett, oanm2000, allagui10, civilteam, aslam, zrilek, cristi, sasan7351, monter, waterman57, yutt, sodapas, alohaloha, Clouseau, Quantumm, fer962933, bigone, cesar3226, hoxuantu, kowheng, ting tsai huang, valinhas, knrsa, kostis, Nilupa, iam_td, peymanlord, saed, devilmaycry, ykhackhack
 kvtasp
User ID: 7690
Threads: 69
Likes: 2,028 in 379 posts
Given Likes: 791
12-12-2011, 02:44 AM
Made By CivilEA Post-Generator ver 2.1.2
[-] The following 7 users Like kvtasp's post:7 users Like kvtasp's post
  • kowheng, Dell_Brett, mastermind, devilmaycry, gacella, ykhackhack, oanm2000
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,709 in 1,305 posts
Given Likes: 4621
06-12-2012, 03:20 PM (This post was last modified: 11-30-2012, 09:40 AM by lisine.)
[-] The following 23 users Like lisine's post:23 users Like lisine's post
  • devilmaycry, 3fan, zrilek, jcbv, malc, slowet, ykhackhack, kowheng, tang1942, Jackass, mastermind, WangJiangchaocn, zego2000, shadabg, oanm2000, Ivan_1980, suseeraj, 88FeNIX, Williams, Dell_Brett, milova, warlord1, dinu69in
07-25-2012, 08:16 AM
Mirror :
[-] The following 4 users Like shadabg's post:4 users Like shadabg's post
  • Dell_Brett, oanm2000, cace-01, Williams
11-30-2012, 05:16 AM (This post was last modified: 11-30-2012, 09:41 AM by lisine.)
[-] The following 1 user Likes shadabg's post:1 user Likes shadabg's post
  • david-smith
 chukwuma
Nigeria
User ID: 54070
Threads: 6
Likes: 37 in 20 posts
Given Likes: 34
03-22-2015, 06:32 PM
Please repost
 f_slikken
User ID: 21091
Threads: 13
Likes: 910 in 88 posts
Given Likes: 778
03-23-2015, 08:29 AM
2shared link on post #3 is still active.
PLZ check prior to posting request.
[-] The following 4 users Like f_slikken's post:4 users Like f_slikken's post
  • boboholala3, PinkPant, albani, chukwuma
  Capacity Design Optimization of Steel Building Frameworks Using Nonlinear Time-Histor TurboXUser 0 3,013 10-13-2016, 04:05 PM
Last Post: TurboXUser
  Analysis and Design of Reinforced Concrete Shell Elements - MSc Thesis asim99 1 2,523 04-04-2014, 02:58 PM
Last Post: Mohammad6299
  OPTIMUM DESIGN OF PIN-JOINTED 3-D DOME STRUCTURES USING GLOBAL OPTIMIZATION TECHNIQUE TAFATNEB 1 1,962 11-26-2013, 06:09 AM
  EVALUATION OF HIGH STRENGTH CONCRETE PRESTRESSED BRIDGE GIRDER DESIGN - Msc Thesis asim99 1 2,185 11-17-2013, 08:49 AM
Last Post: st77bel
  THESIS - Design of walls with linear elastic finite element methods parhyang 2 3,021 09-28-2012, 07:44 PM
Last Post: Grunf
  ARCH BRIDGES, Design-Construction-Perception Thesis by Stefania Palaoro gulilero 0 1,629 09-22-2012, 09:10 PM
Last Post: gulilero
  Analysis and Design of Box Culverts [MSc Thesis] ska51 1 2,590 09-22-2012, 01:19 PM
