Civil Engineering Association eBooks General Books Fundamentals of Marine Riser Mechanics - Basic Principles and Simplified Analysis
 hich
User ID: 3732
Threads: 93
Likes: 5,003 in 418 posts
Given Likes: 101
06-04-2011, 12:55 PM
Author: Sparks, Charles P. | Size: 13.9 MB | Format: PDF | Publisher: PennWell | Year: 2007 | pages: 359 | ISBN: 9781593700706
[Image: 64272914457154773647.jpg]
The author has written this definitive work on the fundamentals of riser mechanics, with the aim of increasing understanding of many aspects of riser static and dynamic behavior. This book is based on the author’s 28 years of experience with riser analysis and, in particular, on his previous publications, some of which have become classics of riser literature. Basic principles are clearly established using several different complementary approaches and the primary parameters that influence riser behavior are identified. This book is a must-own, for anyone who deals with riser design and analysis or with riser technology, from the classroom student to the offshore drilling platform engineer.
1. Introduction
2. Pipe and Riser Deflections and Global Stability: The Effective Tension Concept
3. Application of Effective Tension: Frequent Difficulties and Particular Cases
4. Pipe and Riser Stresses
5. Pipe and Riser Strains
6. Tensioned-Beam Behavior
7. Statics of Near-Vertical Cables
8. Near-Vertical Riser Static Behavior
9. Stress Joint Design
10. Riser Bundles: Local Bending between Guides
11. Near-Vertical Risers Associated with Floating Platforms with Stiff Tensioners
12. Steel Catenary Risers
13. Axial Vibrations of Fixed Risers
14. Axial Vibrations of Hung-off Risers
15. Transverse Modal Vibrations of Near-Vertical Risers
Appendices
Index
Mirror:
[-] The following 8 users Like hich's post:8 users Like hich's post
  • kowheng, jcbv, sodapas, blaze, yantonegr, ELAHI1979, zrilek, Jackass
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
04-27-2013, 06:35 PM (This post was last modified: 04-27-2013, 06:36 PM by ssobhan.)
Mirror;
[-] The following 5 users Like ssobhan's post:5 users Like ssobhan's post
  • Dell_Brett, snags27, subin91, seriousboy, qeddy
  Wind Energy: Fundamentals, Resource Analysis and Economics struceng 3 3,446 02-12-2011, 09:52 AM
