Civil Engineering Association eBooks Structural Books Steel SCI P183: Design of Semi-continuous Braced Frames
04-16-2011, 05:39 AM
Author: G H Couchman | Size: 1.5 MB | Format: PDF | Publisher: SCI | Year: 1997 | pages: 72 | ISBN: 1859420591
[Image: 58848391606291579793.jpg]
In a semi-continuous frame the degree of continuity between the beams and columns is greater than that assumed in simple design, but less than that assumed in continuous design. The degree of continuity can be chosen to produce the most economic balance between the primary benefits associated with these two traditional alternatives.
This document presents a method of analysis and design which permits semi-continuous braced steel frames to be designed by hand. The method is only marginally more complex than that for simple design, and the connection details are straightforward (and therefore inexpensive). Connection forces and moments can be chosen so that column stiffening is not required. Despite this economy of both design effort and fabrication costs, when compared with simple design, it is possible to achieve:
- reduced beam depths
- reduced beam weights.
Procedures are given for checks at both the ultimate and serviceability limit states. For normal design the practising engineer need only consult the main body of the document and the standard connection capacity tables given in Appendix C (yellow pages). A worked example of the approach is included in Appendix A. Appendix B gives a full procedure for estimating deflections more accurately, should this be required.
[-] The following 26 users Like ir_71's post:26 users Like ir_71's post
  • malc, kowheng, hmwere, blaze, jcbv, vvvv, toa011, seriousboy, oanm2000, sheb101, cordoba123, nuttapolk, zrilek, chenamoy, robertsas, cristi, jferrer, nowanda, Nilupa, sodapas, baikur, kmmh76, slowet, ykhackhack, gulilero, bigone
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
11-15-2012, 04:06 PM
all links dead; mirror
word
[-] The following 4 users Like andersen3's post:4 users Like andersen3's post
  • ykhackhack, Dell_Brett, Trishu999, bigone
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
11-15-2012, 04:37 PM
Direct link:
[-] The following 6 users Like ssobhan's post:6 users Like ssobhan's post
  • ykhackhack, gulilero, Dell_Brett, subin91, bigone, milova
  Plastic design of low-rise frames malc 0 1,579 10-06-2020, 03:46 AM
Last Post: malc
  Behavior of Long Links in Eccentrically Braced Frames - Engelhardt, M D; Popov, E P andersen3 3 3,131 12-26-2015, 03:55 PM
Last Post: PinkPant
  Analysis, Design and Construction of Braced Barrel Vaults ssobhan 5 3,692 12-19-2014, 08:37 AM
  Seismic Design of Buckling-Restrained Braced Frames carolinandra 0 1,914 02-17-2013, 05:37 PM
Last Post: carolinandra
  Non-Linear Static and Cyclic Analysis of Steel Frames with Semi-Rigid Connections Flexi 3 3,886 08-10-2012, 02:57 AM
Last Post: miquan
  Steel Building Design: Medium Rise Braced Frames ir_71 2 3,121 01-28-2012, 08:52 PM
Last Post: joker™
  behavior of long links in eccentrically braced frames preceptor 0 2,517 11-29-2009, 07:55 PM
Last Post: preceptor
