Civil Engineering Association eBooks Codes, Manual & Handbook AS3995-1994 Design of Steel Lattice Towers & Masts
Thread Closed
 l_namali
User ID: 2969
Threads: 11
Likes: 498 in 47 posts
Given Likes: 130
04-11-2011, 12:03 PM (This post was last modified: 08-02-2011, 12:45 PM by Grunf.)
Document Type: Standard
Status: Current
Publisher: Standards Australia
Committee: BD-073
Supersedes: AS 3995(Int)-1991 and DR 93147
Abstract
This Standard sets out procedures for the determination of design wind speeds and wind loads to be used in the structural design of steel lattice towers and masts for communication purposes. It further sets out the basis for the strength assessment of members and connections of lattice towers and masts. This Standard incorporates design and analysis of guyed lattice towers and masts, design of cable tension members, footing design and criteria for assessment of existing structures. Guidance relating to maintenance and inspection, and access to steel lattice towers and masts is given in the Appendices. It is not intended to apply to the structural design of transmission line structures. The design of aluminium and cold-formed steel, other than those complying with AS 1163, is not covered by this Standard, except in relation to access to the lattice towers and masts.
Scope
This Standard sets out the procedures for determination of design wind speeds and wind loads, and other appropriate standards to be used in the structural design of steel lattice towers and masts, with or without ancillaries such as antennas, for communication purposes. It also applies to other lattice towers and masts where the predominant load is wind load on the structure. It further sets out the basis for the strength assessment of members and connections of lattice towers and masts.
This Standard is not intended to apply to the structural design of transmission line structures. The design of cold-formed steel, other than those complying with AS 1163, and aluminium is not covered by this Standard.
For all other aspects of design not specifically mentioned herein, reference shall be made to the appropriate Australian Standards including AS 1170 Parts 1 and 2, AS 1554, AS 1559, AS 1650, AS 3569 and AS 4100.
NOTES:
1 A general framework for maintenance and inspection of existing structures is given in Appendix A.
2 Recommendations for access to steel lattice towers and masts are given in Appendix B. If required by the Health and Safety Authority, provision of safe access to such structures should be considered at the design stage.
File size: 457.6 KB
Title, info and file size added. Moved from bad e-book posts. (Grunf)
[-] The following 4 users Like l_namali's post:4 users Like l_namali's post
  • blaze, malc, Quantumm, sivlad
  TIA/EIA 222-F, G - Structural Standards for Steel Antenna Towers and Antenna ascetic19 10 8,216 05-20-2014, 03:35 PM
Last Post: junaid
  NEPAL NATIONAL BUILDING CODE (NBC 000:1994) imran 1 2,044 02-19-2010, 08:42 AM
Last Post: Grunf
