Civil Engineering Association eBooks Codes, Manual & Handbook AS3850-2003 Tilt Up Concrete Construction
 l_namali
User ID: 2969
Threads: 11
Likes: 498 in 47 posts
Given Likes: 130
04-11-2011, 12:01 PM (This post was last modified: 04-11-2011, 12:07 PM by kowheng.)
[-] The following 6 users Like l_namali's post:6 users Like l_namali's post
  • osin, blaze, malc, sivlad, milova, harsono
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 50
Likes: 4,962 in 637 posts
Given Likes: 3500
04-19-2011, 12:33 PM (This post was last modified: 04-19-2011, 02:11 PM by Grunf.)
AS 3850—2003 Tilt-up concrete construction
Size: 0.8 MB | Format: PDF | Publisher: Standards Australia | Year: 2003 | pages: 65 | ISBN: 0 7337 5337 X
[Image: 74161807296269689705.jpg]
This Standard was prepared by the Standards Australia Committee BD-066, Tilt-up
Construction, to supersede AS 3850.1—1990, Tilt-up concrete and precast concrete
elements for use in buildings Part 1: Safety requirements, AS 3850.2—1990, Tilt-up
concrete and precast concrete elements for use in buildings Part 2: Guide to design, casting
and erection of tilt-up panels and AS 3850.3—1992 Tilt-up concrete and precast concrete
elements for use in buildings Part 3: Guide to the erection of precast concrete members in
response to the call from industry to update them and regulatory authorities to expand the
requirements relating to safety. The Standard is to be read in conjunction with AS 3600,
Concrete structures.
Although the Standard has been written primarily to address the construction of concrete
buildings using ‘tilt-up’ panels, the rules may be appropriate for other forms of precast
concrete construction.
A ‘Tilt-up’ panel is defined as ‘an essentially flat concrete panel; cast in a horizontal
position, usually on-site; initially lifted by rotation about one edge until in a vertical or
near-vertical position; transported and lifted into position if necessary; and then stabilized
by bracing members until incorporated into the final structure’.
The terms ‘normative’ and ‘informative’ have been used in this Standard to define the
application of the appendix to which they apply. A ‘normative’ appendix is an integral part
of a Standard, whereas an ‘informative’ appendix is only for information and guidance.
In the Standard where the word ‘shall’ is used a mandatory requirement is implied and
where the word ‘should’ is used the requirement is advisory.
Made By CivilEA Post-Generator ver 2.1[/i][/url][/size][/align]
concrete solution advocate
[-] The following 6 users Like concreteok's post:6 users Like concreteok's post
  • oanm2000, lasalleguy, zrilek, Trishu999, sivlad, tarekfarah
  Code of Practice for Precast Concrete Construction - 2003 - Hongkong ir_71 2 3,809 09-18-2013, 02:39 PM
Last Post: ssobhan
