Civil Engineering Association eBooks Structural Books Steel SCI P264: Wind-moment Design of Unbraced Composite Frames
03-31-2011, 12:32 PM (This post was last modified: 12-12-2011, 11:03 PM by usman.)
SCI P 264 Wind-moment Design of Unbraced Composite Frames
Author: J S HENSMAN, A G J WAY | Size: 0.9 MB | Format: PDF | Publisher: SCI | Year: 2000 | pages: 86 | ISBN: 1859421148
[Image: 22142867490487316539.jpg]
This publication presents procedures for the design of wind-moment composite frames in accordance with BS 5950-1 and BS 59550-3. In this method of design, the frame is made statically determinate by treating the connections as pinned under vertical loads and fixed under horizontal loads (with certain assumed points of zero moment). The publication gives design procedures for frames (with composite beams, slabs and connections) that are braced in the minor axis direction. The limitations of the method are explained. In particular, it should be noted that the method is only recommended for low-rise frames up to four storeys high. In addition to design procedures for the ultimate and serviceability limit states, fully worked design example is presented. The publication also reproduces the resistance tables for standard wind-moment composite connections taken from SCI/BCSA publication Joints in steel construction: Composite connections. These connections use steel reinforcement, flush end plates and grade 8.8 M20 or M24 bolts, and achieve sufficient rotation capacity by ensuring that the moment resistance is not governed by local concrete crushing or bolt or weld failure.
[-] The following 24 users Like ir_71's post:24 users Like ir_71's post
  • seriousboy, kowheng, lamkin, blaze, Grunf, hmwere, vvvv, malc, jcbv, Clouseau, jferrer, ting tsai huang, ikoleci, zrilek, nuttapolk, monter, knrsa, Nilupa, Adam Smith, kmmh76, tang1942, gulilero, ykhackhack, bigone
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
11-15-2012, 03:45 PM
all links dead; mirror
word
[-] The following 7 users Like andersen3's post:7 users Like andersen3's post
  • oanm2000, gulilero, Trishu999, ykhackhack, eliseo.as, chenamoy, bigone
 andersen3
User ID: 464
Threads: 54
Given Likes: 1243
11-18-2013, 06:24 AM
new link:
password:
  • engricardo, bigone, zrilek
  Plastic design of low-rise frames malc 0 1,584 10-06-2020, 03:46 AM
Last Post: malc
  Moment Resistant Connections of Steel Frames in Seismic Areas: Design and Reliability Grunf 4 5,200 09-07-2014, 09:44 PM
Last Post: apocalipse
  SCI: Wind Moment Design of Low Rise Frames gboyega 2 2,968 04-04-2012, 09:48 AM
Last Post: ssobhan
  SCI: Wind-moment design for unbraced steel frames ebcivilea 1 2,628 06-12-2011, 01:18 PM
Last Post: Dell_Brett
