Civil Engineering Association Forum Discussion FAQs, Q&A, comments [PROBLEM] Problem with Postgen
Thread Closed
[Problem] Problem with Postgen
03-31-2011, 05:24 AM
Dear Admin, Dear Protectors and Moderators,I think there is a problem with text formating in postgen since this morning.
I also saw that the medals are gone. Is this had happened by chance or they will no longer exist?
If medals continue to exist, I believe that the Forum team must establish clear criteria for their receipt - the number of posts,
number of threads or number of points .
Best Regards
IR
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 278
Likes: 21,151 in 2,347 posts
Given Likes: 4238
03-31-2011, 07:24 AM
please explain more about bug in POSTGEN (V1 or V2)?
Medals will be back again, we have a procedure for assign medals.
[-] The following 1 user Likes Administrator 's post:1 user Likes Administrator 's post
  • ir_71
03-31-2011, 08:46 AM
Dear Admin,
I use postgen 2.0 since it is avaible. Up to this morning I haven't any problems with postgen both v.1 and v.2
Today, when I tried to post new thread a big mess happened. The font size was changed. The parasite texts appeared, such as "[/font]" ; "[font size]" "[font tahoma]" and other similar.
I will try to post something new if the problem persist I will inform you.
IR
[-] The following 2 users Like ir_71's post:2 users Like ir_71's post
  • Dell_Brett, Grunf
03-31-2011, 12:06 PM (This post was last modified: 03-31-2011, 12:07 PM by ir_71.)
Dear Admin,
this happened two minutes ago, when I post new thread:
I'm using Google Chrome browser.
IR
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,982 in 4,091 posts
Given Likes: 612
03-31-2011, 12:32 PM
Moved to bad posts until Admin will see. Will be corrected and removed to the original section by books moderator after study.
  • Grunf, ir_71
03-31-2011, 12:39 PM (This post was last modified: 03-31-2011, 12:40 PM by ir_71.)
Dear BennyP,
just some seconds ago, I used Opera browser to post new thread and everything was OK. There were no problem with postgen v.2 and Google Chrome up to this morning.
RegardsIR
[-] The following 1 user Likes ir_71's post:1 user Likes ir_71's post
  • Grunf
 cesar
User ID: 31044
Threads: 6
Likes: 93 in 14 posts
Given Likes: 49
03-31-2011, 02:20 PM
it is the same problem happened to me & the warning level because of that rise up to 20%
i try to use the two post generators but the same thing happened those give me fonts on links please fix this problem or i will being banned due to post more links with non desired fonts
03-31-2011, 02:25 PM
Dear members,
I suggest you to stop making posts for day or two, till we fix all of the bugs, or at least till we fix the post-generator bug.
Or make your post(s), but edit them manualy. Read CivilEA Manual for help in editing posts:
Be patient, we are working on forum improvements.
With regards,
Forum Staff
[-] The following 2 users Like Grunf's post:2 users Like Grunf's post
  • ir_71, Administrator
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
03-31-2011, 02:47 PM
As you see i can post without errors. Learn to use codes and even in post generator check, correct, preview and post only if the post looks as you wish. If not use the Grunf's advice and stop posting.
  • kowheng, Grunf
 cesar
User ID: 31044
Threads: 6
Given Likes: 49
03-31-2011, 04:28 PM
(03-31-2011, 02:47 PM)BennyP Wrote: As you see i can post without errors. Learn to use codes and even in post generator check, correct, preview and post only if the post looks as you wish. If not use the Grunf's advice and stop posting.
what about my warning level added by kowheng for posting links today with the problem of fonts
Pages (2): 1 2 Next »
