Civil Engineering Association eBooks General Books Mechanics & Material Technology (Elasticity, Plasticity and Nonlinearity) Linking Models and Experiments
03-26-2011, 06:25 AM
Linking Models and Experiments, Volume 2: Proceedings of the 29th IMAC, A Conference on Structural Dynamics, 2011
Author: Proulx, Tom (Ed.) | Size: 37.5 MB | Format: PDF | Publisher: Springer | Year: 2011 | pages: 446 | ISBN: 9781441993045
[Image: 37630826406859579269.jpg]
ABOUT THIS BOOK
Linking Models and Experiments, Volume 2. Proceedings of the 29th IMAC, A Conference and Exposition on Structural Dynamics, 2011, the second volume of six from the Conference, brings together 33 contributions to this important area of research and engineering. The collection presents early findings and case studies on fundamental and applied aspects of Structural Dynamics, including papers on Finite Element Techniques, Model Updating, Experimental Dynamics Substructuring, Model Validation, and Uncertainty Quantification.
Content Level » Research
Keywords » Finite Element Techniques - Model Updating, Experimental Dynamics - Model Validation - Substructuring - Uncertainty Quantification
Related subjects » Mathematical & Computational Methods - Mechanics - Space Exploration and Astronautics
Table of contents:
1 Modal Testing and FE-model Validation of Azimuthing Thruster 1
V. Nieminen, VTT Technical Research Centre of Finland; M. Tervonen,
Seinäjoki University of Applied Sciences
2 POD Based Computation of Joint Interface Modes 19 of Mechatronics GmbH
3 Area Wise Application of Contact Constraints in Reduced Mechanical Systems 29
4 On the Extension of Global Vibration Modes With Ritz-vectors Needed for Local Effects 37
of Applied Sciences; H. Irschik, H. Holl, Johannes Kepler University - Linz; K. Mayrhofer, Siemens VAI Metals Technologies GmbH
5 Direct Decoupling of Substructures Using Primal and Dual Formulation 47
6 Spectral Analysis of Vibrating Plates With General Shape 77
G. Catania, S. Sorrentino, University of Bologna
7 Smoothing Experimental Data in Dynamic Substructuring of Built up Systems 89
A. Culla, Università di Roma La Sapienza; W. D'Ambrogio, Università dell'Aquila;
A. Fregolent, A. Schiavone, Università di Roma La Sapienza
8 Metrics for Diagnosing Negative Mass and Stiffness When Uncoupling Experimental and Analytical Substructures 111
M.S. Allen, D.C. Kammer, University of Wisconsin-Madison; R.L. Mayes,
9 Propagation of Free-interface Substructure Uncertainty into System Test-analysis Correlation 135
D.C. Kammer, S. Nimityongskul, D. Krattiger, University of Wisconsin W. D'Ambrogio, Universita dell'Aquila; A. Fregolent, Universita di Roma La Sapienza W. Witteveen, University of Applied Sciences - Wels; K. Sherif, Linz Centre W. Witteveen, University of Applied Sciences - Wels K. Sherif, Linz Centre of Mechatronics GmbH; W. Witteveen, University Sandia National Laboratory viii
10 Feature Extraction for Structural Dynamics Model Validation 153
University of Sheffield; G. Park, Los Alamos National Laboratory; N. Takeda,
11 Hybrid Sets of Merged Data for Modal Model Applications 165
L. Thibault, B. LeBlanc, P. Avitabile, University of Massachusetts Lowell
12 Dynamic Uncoupling of a System Model for Component Identification 173
D. Cloutier, P. Avitabile, University of Massachusetts Lowell
13 Full Field Dynamic Stress/Strain From Limited Sets of Measured Data 187
P. Pingle, P. Avitabile, University of Massachusetts Lowell
14 Limited Experimental Displacement Data Used for obtaining Full-field Dynamic
Stress Strain Information 201
15 A Survey of Techniques to Estimate the Uncertainty in Material Parameters 219
T. Simmermacher, Sandia National Laboratories
16 Construction of DEM-base Traffic Model Using Optimal Velocity Model 231
T. Koizumi, N. Tsujiuchi, R. Akatsuka, Doshisha University
17 Confidence Intervals of Modal Parameters During Progressive Damage Test 237
L. Mevel, INRIA; W. Rücker, BAM Federal Institute for Material Research and Testing
18 Identification of Material Properties of Composite Plates Utilizing Model Updating
and Response Surface Techniques 251
K. Gurses, B. Kuran, C. Gencoglu, Roketsan A.S.
19 Globally Enriched Substructuring Techniques for Vibro-acoustic Simulation 263
U. Tabak, D.J. Rixen, Delft University of Technology
20 A Modal-geometrical Selection Criterion for Master Nodes: Numerical and Experimental
Testing 281
E. Bonisoli, C. Delprete, C. Rosso, Politecnico di Torino
21 Robust Optimization and Quality Control in Spot Welded Structures 297
Q.I. Bhatti, M. Ouisse, S. Cogan, Université de Franche-Comté
22 Interface Reduction in the Dual Craig-Bampton Method Based on Dual Interface Modes 311
23 A Truly Hybrid Approach to Substructuring Problems Using Mixed Assembly
and Implicit Solving Strategies 329
S.N. Voormeeren, P.L.C. van der Valk, D.J. Rixen, Delft University of Technology
M. Nishio, University of Tokyo; F. Hemez, Los Alamos National Laboratory; K. Worden,
University of Tokyo; C. Farrar, Los Alamos National Laboratory M. Döhler, INRIA; F. Hille, BAM Federal Institute for Material Research and Testing; X.-B. Lam, ix
24 Model Updating Methodologies for Multibody Simulation Models: Application to a Full-scale Wind Turbine Model 349
S. Manzato, B. Peeters, A. Toso, H. Van der Auweraer, LMS International; R. Osgood,
National Renewable Energy Laboratory
25 DOF Reduction Strategy for Large Order Finite Element Models 359
R.N. Coppolino, Measurement Analysis Corporation
26 Understanding Large Order Finite Element Model Dynamic Characteristics 367
27 FEM Sensitivity Method for Uncertainty and Reconciliation Analyses 375
28 Uncoupling Techniques for the Dynamic Characterization of Sub-structures 383
F.C. Batista, Polytechnic Institute of Leiria; N.M.M. Maia, University of Lisbon
29 Receptance Based Normalization of Operational Mode Shapes 393
D. Bernal, Northeastern University
30 Fault Simulation in a Gearbox Using Finite Element Model Reduction Techniques 399
L. Deshpande, N. Sawalhi, R.B. Randall, University of New South Wales
31 Response Measurements of DMS Cabinets and Supporting Truss Structures Under
Environmental and Transient Wind Loads 411
32 Variance Decomposition in the Presence of Epistemic and Aleatory Uncertainty 417
33 A Forecasting Metric for Predictive Modeling 431
S. Atamturktur, Clemson University; F. Hemez, C. Unal, Los Alamos National Laboratory
  • kowheng, blaze, civilphongvan, seriousboy, zrilek, foxxx2010, oanm2000, zainseiya, melkat, draluka, pramsm24, bridgeengineer
  Constitutive Relations under Impact Loadings: Experiments, Theoretical and Numerical gulilero 0 1,507 03-17-2017, 01:30 AM
Last Post: gulilero
  Computational Methods And Experiments In Materials Characterisation ska51 2 2,219 07-10-2014, 08:38 PM
Last Post: ssobhan
  Wind Tunnels: Aerodynamics, Models and Experiments asim99 1 1,760 07-03-2013, 04:45 AM
Last Post: fred2010
  Plasticity of Metals: Experiments, Models, Computation sodapas 0 1,695 09-20-2011, 07:48 PM
Last Post: sodapas
  Buckling Experiments, Shells, Built-up Structures, Composites and Additional Topics ir_71 0 1,558 08-08-2011, 04:16 AM
