Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 13108 Bituminous mixtures - Material specifications
03-20-2011, 06:59 AM
Author: CEN/TC 227 | Size: 2.4 MB | Format: PDF | Publisher: CEN | Year: 2006
[Image: 80462296551301803772.jpg]
Contents of the package:
1. EN 13108-1:2006 Bituminous mixtures - Material specifications - Part 1: Asphalt Concrete
2. EN 13108-2:2006 Bituminous mixtures - Material specifications - Part 2: Asphalt Concrete for very thin layers
This European Standard specifies requirements for mixtures of the mix group Asphalt Concrete for very thin layers for use on roads, airfields and other trafficked areas. This European Standard includes requirements for the selection of the constituent materials. It is designed to be read in conjunction with EN 13108-20 and EN 13108-21. Asphalt Concrete very thin layer mixtures with chemical modified binders not covered by EN 13924 are not covered by this European Standard.
3. EN 13108-3:2006 Bituminous mixtures - Material specifications - Part 3: Soft Asphalt This European Standard specifies requirements for mixtures of the mix group Soft Asphalt for use on roads, airfields and other trafficked areas. This European Standard includes requirements for the selection of the constituent materials. It is designed to be read in conjunction with EN 13108-20 and EN 13108-21. Soft Asphalt mixtures with chemical modified binders not covered by EN 13924 are not covered by this European Standard.
4. EN 13108-4:2006 Bituminous mixtures - Material specifications - Part 4: Hot Rolled Asphalt
This European Standard specifies requirements for mixtures of the mix group Hot Rolled Asphalt for use on roads, airfields and other trafficked areas. This European Standard includes requirements for the selection of the constituent materials. It is designed to be read in conjunction with EN 13108-20 and EN 13108-21. Hot Rolled Asphalt mixtures with chemical modified binders not covered by EN 13924 are not covered by this European Standard.
5. EN 13108-5:2006 Bituminous mixtures - Material specifications - Part 5: Stone Mastic Asphalt
This European Standard specifies requirements for mixtures of the mix group Stone Mastic Asphalt for use on roads, airfields and other trafficked areas. This European Standard includes requirements for the selection of the constituent materials. It is designed to be read in conjunction with EN 13108-20 and EN 13108-21. Stone Mastic Asphalt mixes with chemical modified binders not covered by EN 13924 are not covered by this European Standard.
6. EN 13108-6:2006 Bituminous mixtures - Material specifications - Part 6: Mastic Asphalt
This European Standard specifies requirements for mixtures of the mix group Mastic Asphalt for use on roads, airfields and other trafficked areas. This European Standard includes requirements for the selection of the constituent materials. It is designed to be read in conjunction with EN 13108-20 and EN 13108-21. Mastic Asphalt mixes with chemical modified binders not covered by EN 13924 are not covered by this European Standard.
7. EN 13108-7:2006 Bituminous mixtures - Material specifications - Part 7: Porous Asphalt
This European Standard specifies requirements for mixtures of the mix group Mastic Asphalt for use on roads, airfields and other trafficked areas. This European Standard includes requirements for the selection of the constituent materials. It is designed to be read in conjunction with EN 13108-20 and EN 13108-21. Porous Asphalt mixtures with chemical modified binders not covered by EN 13924 are not covered by this European Standard.
8. EN 13108-8:2006 Bituminous mixtures - Material specifications - Part 8: Reclaimed asphalt
This European Standard specifies requirements for the classification and description of reclaimed asphalt as a constituent material for asphalt mixtures. This European Standard only specifies reclaimed asphalt with bituminous binders: paving grade bitumen, modified bitumen or hard grade bitumen.
9. EN 13108-20:2006 Bituminous mixtures - Material specifications - Part 20: Type Testing
This European Standard specifies Type Testing procedures for use for the validation of bituminous mixtures for use in roads, airfields and other trafficked areas.
10. EN 13108-21:2006 Bituminous mixtures - Material specifications - Part 21: Factory Production Control This European Standard specifies both quality and Factory Production Control requirements for use during the manufacture of bituminous mixtures intended for use on roads, airfields and other trafficked areas. Additional testing carried out within contracts is beyond the scope of this European Standard. The Factory Production Control is to be applied to European Standards for bituminous mixtures if regulatory marking of conformity is to be applied. It is also a necessary part of evaluation of conformity in situations where regulatory marking does not apply. This European Standard is applicable to the control of bituminous mixtures where the constituents and target composition are known, and have been shown by means of Type Testing to comply with all appropriate specified compositional, performance related or performance based requirements in EN 13108-1 to -7.
  • kowheng, usman, blaze, Grunf, st77bel, melkat, Dell_Brett, oanm2000, toa011, lamkin, sivlad
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
06-03-2013, 10:43 AM
direct link for part 1 (2006) , 4(prEN-2012) and 8(prEN-2012)
  • Jackass, st77bel, utan, engrezi, peixoto, kostell
07-28-2014, 11:17 AM
  • zrilek, oanm2000, Mohammad6299, bridgeengineer, fordcell, malc, dinu69in, PinkPant, Dell_Brett
 fordcell
Member
User ID: 25868
Threads: 8
Likes: 138 in 22 posts
Given Likes: 134
07-29-2014, 11:56 AM (This post was last modified: 07-29-2014, 12:12 PM by fordcell.)
In the following link you can find the No21 code but note that it is in French. With some support from Google or Bing or ... translator you may be able to use it though.
I have also upload these 2 corrigendum from 2007 for No1 and No7 code's.
[-] The following 2 users Like fordcell's post:2 users Like fordcell's post
  • malc, Dell_Brett
 rusty
Hungary
User ID: 17227
Threads: 68
Likes: 1,880 in 283 posts
Given Likes: 539
01-04-2019, 09:50 PM
@"ir_71" Could you upload the files again? The links (post #1 and #3) with the package are dead.
  EN 13043:2002/AC Aggregates for bituminous mixtures and surface treatments for roads, ir_71 2 2,803 09-02-2014, 07:58 PM
Last Post: vangjo
  EN 13813:2002 Screed material and floor screeds - Screed material - Properties and re ir_71 1 2,798 05-04-2011, 12:19 PM
