Civil Engineering Association eBooks Codes, Manual & Handbook AISC AISC LOAD AND RESISTANCE FACTOR DESIGN SPECIFICATIO 1999
 Hengki
User ID: 17300
Threads: 29
Likes: 437 in 30 posts
Given Likes: 1678
03-15-2011, 07:20 PM (This post was last modified: 03-15-2011, 09:47 PM by Grunf.)
‪LOAD AND RESISTANCE FACTOR DESIGN SPECIFICATION 1999‬
Author: AMERICAN INSTITUTE OF STEEL CONSTRUCTION (AISC) | Size: 2.332 MB | Format: PDF | Publisher: AMERICAN INSTITUTE OF STEEL CONSTRUCTION (AISC) | Year: 1999 | pages: 327
The AISC Load and Resistance Factor Design (LRFD) Specification for Structural Steel Buildings is based on reliability theory. As have all AISC Specifications, this Specification has been based upon past successful usage, advances in the state of knowledge, and changes in design practice. This Specification has been developed as a consensus document to provide a uniform practice in the design of steel-framed buildings. The intention is to provide design criteria for routine use and not to provide specific criteria for infrequently encountered problems, which occur in the full range of structural design.
This Specification is the result of the consensus deliberations of a committee of structural engineers with wide experience and high professional standing, representing a wide geographical distribution throughout the U.S. The committee includes approximately equal numbers of engineers in private practice and code agencies, engineers involved in research and teaching, and engineers employed by steel fabricating and producing companies.
The contributions and assistance of more than 50 additional professional volunteers working in 15 task committees are also hereby acknowledged. The Symbols, Glossary, and Appendices to this Specification are an integral part of the Specification. A non-mandatory Commentary has been prepared to provide background for the Specification provisions and the user is encouraged to consult it. The principal changes incorporated in this edition of the Specification include:
• Dual units format. Values and equations are given in both U.S. customary and metric units. The metric conversions (given in parentheses following the U.S. units) are based on ASTM E380, Standard Practice for Use of the International System of Units (SI). The equations are non-dimensionalized where possible by factoring out material constants, such as E and G.
• Inclusion of new structural steels ASTM A913 and A992.
• Additional notch toughness requirements for complete-joint-penetration groove welds with tension applied normal to the effective area.
• New provisions for stability bracing of beams, columns, and frames.
• New Chapter N for evaluation of existing structures.
• Revised provisions for member design under fatigue loading in Appendix K.
• Reorganization of material on pin-connected members and eyebars.
• Revised provisions for concrete-encased beams.
• New limitation on the stud reduction factor when a single stud is used in a rib.
• Revised bolt bearing strength criteria.
DIRECT LINKS thumbup
[-] The following 11 users Like Hengki's post:11 users Like Hengki's post
  • vardan, seriousboy, strengr, rendel_©, Jackass, madkestas, lucas, ISTRAKTURA, hm20284, Jarty, nickycruz
 amindoxiti
User ID: 86739
Threads: 203
Likes: 8,341 in 584 posts
Given Likes: 2618
07-01-2014, 12:21 AM
The link is dead,could you please reupload a new one.
regards
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
07-01-2014, 02:07 PM
Mirror;
direct link;
[-] The following 8 users Like ssobhan's post:8 users Like ssobhan's post
  • Mohammad6299, PinkPant, Dell_Brett, amindoxiti, malc, mgdario, learner20, spat
  AISC - Steel Design Guides Administrator 74 80,792 08-18-2025, 06:17 AM
  AISC 327: Seismic Design Manual weichunc 15 13,448 04-20-2023, 11:57 AM
Last Post: cheosmith
  AISC 205: AISC Certification Program for Steel Bridge Fabricators Administrator 2 3,952 01-19-2022, 05:18 AM
  AISC Load and Resistance Factor Design Specification for Single-Angle Members Hengki 3 3,827 01-18-2022, 01:29 PM
  AISC Design Examples babak 16 10,953 01-18-2022, 12:50 PM
  AISC 316: AISC Manual of Steel Construction Grunf 3 6,478 04-08-2020, 04:53 AM
Last Post: KMABD
