Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Books and Codes Request [REQUEST] ECCS No125 - Buckling of Steel Shells, European Design Recommendations, Eurocode 3
[Request] ECCS No125 - Buckling of Steel Shells, European Design Recommendations, Eurocode 3
 jcbv
User ID: 19792
Threads: 31
Likes: 962 in 84 posts
Given Likes: 7825
11-05-2010, 07:19 AM (This post was last modified: 03-09-2015, 03:19 PM by usman.)
Buckling of Steel Shells - European Design Recommendations
[Image: 09890275249826767952.jpg]
Nº125, 5th edition, 2008
Editors: John Michael Potter and herbert Scmidt, TC8 - Stability (TWG 8.4)
This document is the 5th Edition of the ECCS European Recommendations for the Buckling of Steel Shells. It is the successor to the 4th Edition, published in 1988, which was very different in style, format and content, though some of the regulatory requirements of the 4th Edition are here retained in the 5th Edition. In the 20 years since the publication of the 4th Edition in 1988, much has changed in the field of metal shell buckling. Extensive research has been undertaken, much new knowledge has been developed, and powerful computational modelling has transformed the field, though much design is still conducted by hand calculation. These changes are reflected in this 5th Edition.
The 5th Edition quotes extensively from the Eurocode EN 1993-1-6 (2007) and is completely compatible with that standard.
However, the Eurocode has no commentary, so the meaning, limitations and origins of many rules are not always clear. This 5th Edition provides an extensive commentary on the existing rules relating to buckling in the Eurocode, but extends far beyond it in giving recommendations, expansions, advice and warnings, explanations and examples, all of which should give the user< considerably more insight and confidence in applying the rules of EN 1993-1-6.
Structure of the document This 5th Edition is divided into two parts. Part I sets out the basic information and general procedures required to undertake all shell buckling calculations according to EN 1993-1-6. It describes the methodology and conceptual principles for numerical analysis, either to derive the basic data that can be used in a straightforward buckling design by hand calculation, or to replace parts of this calculation with numerical assessments, or to carry out a buckling design that is completely based on numerical assessment.
Part II sets out the detailed information for hand calculation procedures when a shell of a particular geometry is being designed for a particular loading condition. Many well-proven engineering formulas, empirical data and simplified rules extracted from numerical parametric studies have been included in this part. In particular, Part II contains radically updated versions of the rules set out in the 4th Edition of the ECCS Recommendations.
[-] The following 7 users Like jcbv's post:7 users Like jcbv's post
  • rezart, sasan7351, oanm2000, waterman57, jocagalhao, Nilupa, astolfo
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
11-21-2014, 10:26 AM
  • Article/eBook Full Name: Buckling of Steel Shells, European Design Recommendations, Eurocode 3, Part 1-6 , 5th Edition Revised Second Impression
  • Author(s): J.M. Rotter
  • Publish Date: 2013
  • Related Links:
[Image: 86296467973993727917.jpg]
[-] The following 2 users Like ssobhan's post:2 users Like ssobhan's post
  • apocalipse, jcbv
 usman
User ID: 59
Threads: 138
Likes: 6,571 in 671 posts
Given Likes: 4974
03-09-2015, 02:59 PM (This post was last modified: 03-09-2015, 03:14 PM by usman.)
follow
[-] The following 2 users Like usman's post:2 users Like usman's post
  • malc, Aviator
 eng_struc
engineer
Uruguay
User ID: 53888
Threads: 19
Likes: 22 in 9 posts
Given Likes: 31
09-05-2017, 06:39 PM (This post was last modified: 09-05-2017, 08:02 PM by amindoxiti. Edit Reason: N/A )
Publish Date: 2013
Related Links:
This is a request for the newest version of this publication: "REVISED 2ND IMPRESSION" of the 5th edition.
Many thanks
  [REQUEST] SEAOC Blue Book - Seismic Design Recommendations 2019 sabooryan 2 2,260 05-28-2020, 09:15 AM
  [REQUEST] ECCS Publications Request ec03152 0 1,123 05-14-2020, 08:16 AM
Last Post: ec03152
  [REQUEST] Recommendations for the design of prestressed concrete oil storage tanks temp1366 0 1,193 09-21-2019, 05:11 PM
Last Post: temp1366
  [REQUEST] Design Recommendations for Seismically Isolated Buildings sabooryan 0 1,245 12-28-2017, 03:57 PM
Last Post: sabooryan
  [REQUEST] Recommendations for the design of structures subject to traffic loading to BS EN 1997 hmwere 3 2,019 04-30-2017, 03:36 PM
Last Post: ziggywas1
  [REQUEST] Joints in steel construction: Moment-Resisting Joints to Eurocode 3 azbukvid 1 1,612 03-10-2017, 03:33 PM
Last Post: civilphongvan
  [REQUEST] Design of Composite Steel and Concrete Structures with Worked Examples to Eurocode 4 jmksq 0 1,419 03-04-2017, 03:07 PM
Last Post: jmksq
