Civil Engineering Association eBooks General Books Mechanics & Material Technology (Elasticity, Plasticity and Nonlinearity) Intermediate Mechanics of Materials - by J R Barber
 jcbv
User ID: 19792
Threads: 31
Likes: 962 in 84 posts
Given Likes: 7825
02-07-2011, 10:43 AM (This post was last modified: 03-08-2013, 06:01 PM by usman.)
Intermediate Mechanics of Materials,2 Edition
Author: J. R. Barber | Size: 9 MB | Format: PDF | Publisher: Springer | Year: 2010 | pages: 618 | ISBN: 9400702949
[Image: 06731753215985622515.jpeg]
This book covers the essential topics for a second-level course in strength of materials or mechanics of materials, with an emphasis on techniques that are useful for mechanical design. Design typically involves an initial conceptual stage during which many options are considered. At this stage, quick approximate analytical methods are crucial in determining which of the initial proposals are feasible. The ideal would be to get within 30% with a few lines of calculation. The designer also needs to develop experience as to the kinds of features in the geometry or the loading that are most likely to lead to critical conditions.
With this in mind, the author tries wherever possible to give a physical and even an intuitive interpretation to the problems under investigation. For example, students are encouraged to estimate the location of weak and strong bending axes and the resulting neutral axis of bending before performing calculations, and the author discusses ways of getting good accuracy with a simple one degree of freedom Rayleigh-Ritz approximation. Students are also encouraged to develop a feeling for structural deformation by performing simple experiments in their outside environment, such as estimating the radius to which an initially straight bar can be bent without producing permanent deformation, or convincing themselves of the dramatic difference between torsional and bending stiffness for a thin-walled open beam section by trying to bend and then twist a structural steel beam by hand-applied loads at one end.
In choosing dimensions for mechanical components, designers will expect to be guided by criteria of minimum weight, which with elementary calculations, generally leads to a thin-walled structure as an optimal solution. This consideration motivates the emphasis on thin-walled structures, but also demands that students be introduced to the limits imposed by structural instability. Emphasis is also placed on the effect of manufacturing errors on such highly-designed structures - for example, the effect of load misalignment on a beam with a large ratio between principal stiffness and the large magnification of initial alignment or loading errors in a strut below, but not too far below the buckling load.
[-] The following 16 users Like jcbv's post:16 users Like jcbv's post
  • Dell_Brett, kowheng, erthqkengnr™, durden, sodapas, essam2109, seriousboy, usman, Quantumm, Nilupa, oanm2000, warbeast, mastermind, gulilero, neikrof, jonny78
08-09-2011, 09:10 AM (This post was last modified: 12-31-2011, 06:06 AM by kowheng.)
Bookmarked PDF|RAR 13.18|9.01 MB
RAR password: KCivilEA
[-] The following 20 users Like kowheng's post:20 users Like kowheng's post
  • Dell_Brett, oanm2000, warbeast, odiclas, julioreptil, foxxx2010, zero85, malc, mastermind, slowet, gulilero, Adam Smith, orambo, lasalleguy, ting tsai huang, cristi, neikrof, pram, lisine, jonny78
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
03-08-2013, 11:51 PM (This post was last modified: 03-08-2013, 11:52 PM by ssobhan.)
direct links; 12 MB
[-] The following 4 users Like ssobhan's post:4 users Like ssobhan's post
  • vardan, cace-01, ali akbar, eseem
  Advanced Mechanics of Materials abudabeeja 16 15,651 09-12-2023, 02:39 PM
Last Post: ASEC
  Statics and Mechanics of Materials SI abudabeeja 6 7,067 09-14-2019, 04:58 AM
Last Post: pezhmankhan
  Mechanics of Materials - Hibbeler niki102 14 13,365 07-23-2018, 09:51 PM
Last Post: azarakhshali
  Mechanics and Strength of Materials Flexi 10 7,230 05-03-2018, 05:45 AM
  Continuum Mechanics of Anisotropic Materials cace-01 3 2,609 04-12-2018, 10:07 AM
  Mechanics of Materials - Formulas and Problems: Engineering Mechanics 2 ssobhan 0 1,736 07-27-2017, 11:00 AM
Last Post: ssobhan
  Mechanics of Materials: With Applications in Excel struceng 1 2,117 03-18-2017, 06:56 AM
Last Post: Veggeta
