Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 12899 Fixed, vertical road traffic signs - All parts
02-01-2011, 12:42 PM
Author: CEN/TC 226 | Size: 3.5 MB | Format: PDF | Publisher: CEN | Year: 2007
[Image: 02559343340344121632.jpg]
Contents of rar-file:
1. EN 12899-1:2007 Fixed, vertical road traffic signs - Part 1: Fixed signs
This Part 1 of EN 12899 specifies requirements for complete sign assemblies (including supports), signs (sign plates with sign faces), sign plates (without sign faces) and for other major components (retroreflective sheeting, supports and luminaires).
The main intended use of fixed signs is for the instruction and guidance of road users on public and private land.
Matters not covered by this standard:
a) sign gantry and cantilever structures;
b) signs with discontinuous messages, e.g. using light emitting diodes (LED), or fibre optics;
c) variable message signs;
d) signs used for temporary purposes;
e) foundations;
f) tests for extremely low temperatures.
2. EN 12899-2:2007 Fixed, vertical road traffic signs - Part 2: Transilluminated traffic bollards (TTB)
This Part 2 of EN 12899 specifies requirements for new transilluminated traffic bollards (TTBs) including their fixing, which may incorporate traffic signs (type 1 TTB) or may support traffic signs (type 2 TTB) to be used in traffic circulation areas.
It covers performance requirements and test methods.
Colorimetric and retroreflective properties as well as luminance of transilluminated illuminated portions are specified taking into account CIE recommendations.
Structural requirements for TTBs include performance under static and dynamic loading.
Provision is made for safety in use, including vehicle impact.
Devices of similar function, but without transillumination or less than 600 mm in height, are not covered.
NOTE Foundations are not specified in this standard but should be adequate to support the loads to be carried.
Unless otherwise stated, clauses in this standard apply to both type 1 and type 2 TTBs.
3. EN 12899-3:2007 Fixed, vertical road traffic signs - Part 3: Delineator posts and retroreflectors
This Part 3 of EN 12899 specifies requirements for new delineator posts and for new retroreflectors as separate products or combined together to be used in traffic circulation areas.
Colorimetric and retroreflective properties are specified taking into account CIE recommendations.
Structural requirements include performance under static and dynamic loading.
To define durability this standard also includes performance levels to be maintained after natural weathering exposure.
No requirements are given for the use of colours, dimensions and tolerances of delineator posts and retroreflectors.
4. EN 12899-4:2007 Fixed, vertical road traffic signs - Part 4: Factory production control
5. EN 12899-5:2007 Fixed, vertical road traffic signs - Part 5: Initial type testing
This Part 5 of EN 12899 describes the requirements for initial type testing (ITT), of Parts 1, 2 and 3 of EN 12899.
  • kowheng, blaze, kmmh76, usman, Grunf, jcbv, ziggywas1, salahcivil, PanosP, dbsimon29, nima103, ziadjordan, Dell_Brett, bubieng
12-11-2012, 06:45 PM
New links:
  • 3fan, Trishu999, blaze, peixoto, zrilek, Jackass, mahyarov
09-22-2013, 06:37 AM
New Links
[-] The following 3 users Like ir_71's post:3 users Like ir_71's post
  • Hengki, Dell_Brett, sodapas
 Mohammad6299
User ID: 42302
Threads: 261
Likes: 7,913 in 854 posts
Given Likes: 4212
02-14-2014, 09:07 PM
Part 1: Fixed Signs
Part 2: Transilluminated Traffic Bollards
Part 3: Elineator Posts And Retroreflectors
Part 4: Factory Production Control
Part 5: Initial Type Testing
[-] The following 3 users Like Mohammad6299's post:3 users Like Mohammad6299's post
  • Dell_Brett, jcbv, uetian19
