Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 14636-1:2009 Plastics piping systems for non-pressure drainage and sewerage
01-28-2011, 03:32 PM
BS EN 14636-1:2009 Plastics piping systems for non-pressure drainage and sewerage — Polyester resin concrete (PRC) Part 1: Pipes and fittings with flexible joints
Author: CEN/TC 155 | Size: 1.27 MB | Format: PDF | Publisher: CEN | Year: 2009 | pages: 82 | ISBN: 9780580537998
[Image: 64454312729646984492.jpg]
This European Standard applies to pipes and fittings made from polyester resin concrete (PRC, see 3.1.23), intended to be used within a drain or sewer system operating without pressure. It applies to products for use in buried installations to be installed by open-trench techniques or pipe jacking. It applies to pipes, fittings and their joints of nominal sizes from DN 150 to DN 3000 for circular cross-sections, from WN/HN 300/450 to WN/HN 1400/2100 for egg-shaped cross-sections and from DN 800 to DN 1800 for kite-shaped cross-sections.
The intended use of these products is for the conveyance of sewage, rainwater and surface water at temperatures up to 50 °C, without pressure or occasionally at a head of pressure up to 0,5 bar1), and installed in areas subjected to vehicle and/or pedestrian traffic.
NOTE 1 The attention of readers is drawn to applicable requirements contained in EN 476. It specifies definitions, requirements and characteristics of pipes, fittings, joints, materials, test methods and marking.
The pipes are classified on the basis of the intended method of installation and cross- sectional shape.
NOTE 2 It is the responsibility of the purchaser or specifier to make the appropriate selections,
[-] The following 4 users Like ir_71's post:4 users Like ir_71's post
  • kowheng, oanm2000, usman, k1k0k0
 arshiakh
User ID: 37777
Threads: 100
Likes: 3,224 in 617 posts
Given Likes: 214
02-22-2013, 03:46 PM
All links are dead.
please reupload it
thanks
  BS 8490:2007 Guide to siphonic roof drainage systems ir_71 5 4,420 12-30-2014, 09:56 PM
Last Post: Veggeta
  BS EN 12380:2002 Air admittance valves for drainage systems mybest 1 1,933 02-21-2013, 09:43 AM
Last Post: arshiakh
  BS 8515:2009 Rainwater harvesting systems – Code of practice ir_71 1 2,327 02-19-2013, 02:15 PM
  BS EN 14758-1:2005 +A1:2009 Plastics piping systems for non-pressure underground drai ir_71 1 2,004 02-14-2013, 12:40 PM
  BS EN 14963:2006 Roof coverings. Continuous rooflights of plastics with or without up mybest 0 1,707 11-28-2011, 05:38 PM
Last Post: mybest
