Civil Engineering Association eBooks Forensic Engineering Corrosion-under insulation (CUI) guidelines
 struceng
Russian Federation
User ID: 258
Threads: 268
Likes: 10,197 in 602 posts
Given Likes: 741
10-09-2009, 02:37 PM (This post was last modified: 02-07-2011, 08:51 AM by Grunf.)
Corrosion Under Insulation (CUI) Guidelines
[Image: 61ihk4o41ybp41hqxm8.jpg]
Info:
Author: European Federation of Corrosion
Editor: S. Winnik
Edition: illustrated
Publisher: Woodhead, 2008
ISBN: 1845694236, 9781845694234
Length: 158 pages
Pdf: 3 Mb
Corrosion under insulation (CUI) refers to the external corrosion of piping and vessels fabricated from carbon manganese, low alloy and austenitic stainless steel that occurs underneath externally clad/jacketed insulation due to the penetration of water. By its very nature CUI tends to remain undetected until the insulation and cladding/ jacketing is removed to allow inspection or when leaks to atmosphere occur. CUI is a common problem shared by the refining, petrochemical, power, industrial, onshore and offshore industries. The European Federation of Corrosion (EFC) Working Parties WP13 and WP15 have worked to provide guidelines on managing CUI together with a number of major European refining, petrochemical and offshore companies including BP, Chevron-Texaco, Conoco-Phillips, ENI, Exxon-Mobil, IFP, MOL, Scanraff, Statoil, Shell, Total and Borealis. The guidelines within this document are intended for use on all plants and installations that contain insulated vessels, piping and equipment. The guidelines cover a risk-based inspection methodology for CUI, inspection techniques (including non-destructive evaluation methods) and recommended best practice for mitigating CUI, including design of plant and equipment, coatings and the use of thermal spray application, types of insulation, cladding/jacketing materials and protection guards. The guidelines also include case studies.
Download Links:
Generated by CivilEA PostGen v1.3
[-] The following 15 users Like struceng's post:15 users Like struceng's post
  • timosi™, timosi™, Dell_Brett, Dell_Brett, aslam, aslam, ajmf77, ajmf77, kowheng, kowheng, baikur, bubieng, jcbv, toa011, Quantumm
01-16-2011, 07:25 AM
Author: S. Winnik | Size: 3.04 MB | Format: PDF | Publisher: Woodhead Publishing Ltd | Year: 2008 | pages: 176 | ISBN: 9781845694234
[Image: 68924760090118697209.jpg]
- guidelines cover inspection methodology for CUI, inspection techniques, including non-destructive evaluation methods and recommended best practice
- case studies are included illustrating key points in the book
Corrosion under insulation (CUI) refers to the external corrosion of piping and vessels that occurs underneath externally clad/jacketed insulation as a result of the penetration of water. By its very nature CUI tends to remain undetected until the insulation and cladding/jacketing is removed to allow inspection or when leaks occur. CUI is a common problem shared by the refining, petrochemical, power, industrial, onshore and offshore industries.
The European Federation of Corrosion (EFC) Working Parties WP13 and WP15 have worked to provide guidelines on managing CUI together with a number of major European refining, petrochemical and offshore companies including BP, Chevron-Texaco, Conoco-Phillips, ENI, Exxon-Mobil, IFP, MOL, Scanraff, Statoil, Shell, Total and Borealis. The guidelines within this document are intended for use on all plants and installations that contain insulated vessels, piping and equipment. The guidelines cover a risk-based inspection methodology for CUI, inspection techniques (including non-destructive evaluation methods) and recommended best practice for mitigating CUI, including design of plant and equipment, coatings and the use of thermal spray techniques, types of insulation, cladding/jacketing materials and protection guards. The guidelines also include case studies.
  • Dell_Brett, jcbv, kowheng, toa011, blaze, oanm2000, usman, Quantumm, rudyhera03, cristi, Grunf, monter
Likes: 33,527 in 2,936 posts
02-07-2011, 08:41 AM (This post was last modified: 10-03-2012, 05:54 AM by kowheng.)
Bookmark PDF|RAR 3.19|2.00 MB
[-] The following 5 users Like kowheng's post:5 users Like kowheng's post
  • Grunf, jcbv, Dell_Brett, toa011, usman
