Civil Engineering Association eBooks Codes, Manual & Handbook API RP 651: Cathodic Protection of Aboveground Petroleum Storage Tanks
01-13-2011, 07:19 AM (This post was last modified: 12-29-2011, 11:47 PM by usman.)
API RECOMMENDED PRACTICE 651 Cathodic Protection of Aboveground Petroleum Storage Tanks
Author: API | Size: 0.75 MB | Format: PDF | Publisher: API | Year: 2007 | pages: 46
[Image: 10072715596067213300.jpg]
1.1 The purpose of this recommended practice is to present procedures and practices for achieving effective corrosion control
on aboveground storage tank bottoms through the use of cathodic protection. It contains provisions for the application of cathodic
protection to existing and new storage tanks. Corrosion control methods based on chemical control of the environment or the use
of protective coatings are not covered in detail.
1.2 When cathodic protection is used for aboveground storage tank applications, it is the intent of this recommended practice to
provide information and guidance specific to aboveground steel storage tanks in hydrocarbon service. Certain practices recommended
herein may also be applicable to tanks in other services. It is intended to serve only as a guide to persons interested in
cathodic protection. Specific cathodic protection designs are not provided. Such designs should be developed by a person thoroughly
familiar with cathodic protection practices.
1.3 This recommended practice does not designate specific practices for every situation because the varied conditions in which
tank bottoms are installed preclude standardization of cathodic protection practices.
  • Dell_Brett, blaze, oanm2000, ssobhan, malc, usman, faros3000, rendel_©
  API 650 Welded Tanks for Oil Storage Ultra Zone 20 13,704 02-23-2022, 03:52 AM
Last Post: malc
  API 620:2009 Design and Construction of Large, Welded, Low-pressure Storage Tanks ir_71 7 6,299 12-29-2021, 06:18 AM
Last Post: malee
  API RP 2350: 2005 Overfill Protection for Storage Tanks in Petroleum Facilities jamildear4u 1 2,500 09-23-2013, 06:21 AM
Last Post: irshad313
  API S 2015: 2001 Safe Entry and Cleaning of Petroleum Storage Tanks jamildear4u 0 1,680 01-12-2012, 08:50 PM
Last Post: jamildear4u
  API RP 652: 2005 Linings of Aboveground Petroleum Storage Tank Bottoms jamildear4u 0 1,568 01-12-2012, 07:47 PM
  API S2000:2009 Venting Atmospheric and Low-Pressure Storage Tanks jamildear4u 0 1,866 01-10-2012, 07:15 PM
