Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 10225:2009 Weldable structural steels for fixed offshore structures — Technical de
01-10-2011, 02:07 PM
EN 10225:2009 Weldable structural steels for fixed offshore structures — Technical delivery conditions
Author: ECISS/TC 10 | Size: 2.39 MB | Format: PDF | Publisher: CEN | Year: 2009 | pages: 80 | ISBN: 9780580646232
[Image: 39456104652021308801.jpg]
This European Standard specifies requirements for weldable structural steels to be used in the fabrication of fixed
offshore structures in the form of plates up to and including 150 mm thick. It also specifies sections up to 63 mm
thick except for sections delivered in the as-rolled condition which are permitted up to 25 mm thick only. Seamless
hollow sections up to and including 40 mm thick and high frequency electric resistance welded hollow sections up
to and including 20 mm thick are specified. Greater thicknesses for sections and hollow sections may be agreed,
provided the technical requirements of this European Standard are maintained.
For plates the thickness limitations are:
S355G2+N, S355G5+M, - up to and including 20 mm
S355G3+N, S355G6+M - up to and including 40 mm
S355G7+N, S355G8+N, S355G9+N, S355G10+N - up to and including 150 mm
S355G7+M, S355G8+M, S355G9+M, S355G10+M - up to and including 100 mm
S420G1+QT, S420G1+M, S420G2+QT, S420G2+M - up to and including 100 mm
S460G1+QT, S460G1+M, S460G2+QT, S460G2+M - up to and including 100 mm
The standard is applicable to steels for offshore structures, designed to operate in the offshore sector but not to
steels supplied for the fabrication of subsea pipelines, risers, process equipment, process piping, and other
utilities. It is primarily applicable to the North Sea Sector, but may also be applicable in other areas provided that
due consideration is given to local conditions e.g. temperature.
In the case of hollow sections formed from plate with the seam fusion welded, this European standard covers only
the requirements of the plate material.
Minimum yield strengths up to 460 MPa are specified together with low temperature impact properties at
temperatures down to –40 °C.
This European standard applies to material supplied ex-mill or from merchant's stock.
  • blaze, usman, oanm2000, malc, Dell_Brett, ssi3k, kowheng, toa011, roaming79, zrilek, mig21
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
01-09-2013, 07:46 AM
mirror here:
pass:
  • Jackass, narendra, Dell_Brett
  EN 13670:2009 Execution of concrete structures ir_71 5 4,916 11-14-2016, 12:15 PM
Last Post: PinkPant
  EN 10084 Case hardening steels - Technical delivery conditions ir_71 0 1,743 10-23-2010, 02:18 PM
