Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Wrap-Around Gusset Plate for Hor Brace With Large Cutout
[Request] Wrap-Around Gusset Plate for Hor Brace With Large Cutout
 michenerpark
Member
Banned
China
User ID: 14276
Threads: 5
Likes: 98 in 27 posts
Given Likes: 11
01-04-2011, 01:46 PM (This post was last modified: 01-04-2011, 04:33 PM by usman.)
Anyone can downlaod this for me from
, or have design guideline of Wrap-Around Gusset plate for horizontal bracing with large cutout please share
Design of wrap around steel gusset plates
by Dowswell, Ronald Scott, PhD, THE UNIVERSITY OF ALABAMA AT BIRMINGHAM, 2005, 0 pages; 3201151
Abstract: Gusset plates are used in steel buildings to connect bracing members to other structural members in the lateral force resisting system. Horizontal bracing is commonly used to resist lateral loads in industrial structures and in commercial buildings where floor and roof diaphragms cannot carry the loads. Wrap-around gusset plates are L-shaped plates that are used where an opening is required at the corner of the plate. This typically occurs at horizontal bracing where the gusset plate is cut out around a column. The purposes of this research were to gain a better understanding of the behavior of wrap-around gusset plates, identify potential failure modes, and formulate a design method for these connections. Ten experimental specimens were tested in compression and five were tested in tension. All of the specimens were modeled using the finite element method with material and geometric nonlinearities. The experiments and finite element models indicated that wrap-around gusset plates are subject to limit states common to flexural members. The results were used to formulate a design method for wrap-around gusset plates, which is based on a cantilever beam model. The accuracy of the proposed design method was verified by comparing the calculated capacities to experimental and finite element results. The accuracy of the proposed method is similar to that of the current design procedure for standard gusset plates without cutouts.
Anyone can downlaod this for me from ASCE site
Finite Element Modeling of Wrap-Around Gusset Plates in Tension by Bo Dowswell, Robert Whyte, Jim Davidson, and Fouad Fouad
Document type: Conference Proceeding Paper
Part of: 2006 Structural Engineering and Public Safety
Abstract: Gusset plates are used in steel buildings to connect bracing members to other structural members in the lateral force resisting system. Horizontal bracing is commonly used to resist lateral loads in industrial structures and in commercial buildings where floor and roof diaphragms cannot carry the loads. Wrap-around gusset plates are L-shaped plates that are used where an opening is required at the comer of the plate. This typically occurs at horizontal bracing where the gusset plate is cut out around a column. Finite element models were used to determine the behavior of wrap-around gusset plates. The plates were modeled using material and geometric nonlinearities. Five different gusset plates were modeled with geometry and material properties matching the experimental specimens of Dowswell. All of the models were loaded in tension. The loads from the finite element models were compared to the experimental loads.
Thanks in advance
 hich
User ID: 3732
Threads: 93
Likes: 5,003 in 418 posts
Given Likes: 101
01-04-2011, 06:36 PM
here they are:
[-] The following 10 users Like hich's post:10 users Like hich's post
  • Grunf, Dell_Brett, yucapareja, michenerpark, Clouseau, lizard, gatob, cardinal85, usman, drkol39
  [REQUEST] Geometric Formulas for Gusset Plate Design carolinandra 3 4,368 01-04-2022, 11:55 AM
  [REQUEST] RC Beam Design with Fiber Wrap. parthiban 1 1,670 10-27-2012, 04:47 AM
Last Post: ykhackhack
  Finite Element Modeling of Wrap-Around Gusset Plates in Tension michenerpark 0 1,836 01-04-2011, 03:19 AM
Last Post: michenerpark
