Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] EN 998-1:2010 and EN 998-2:2010 Specification for mortar for masonry
[Request] EN 998-1:2010 and EN 998-2:2010 Specification for mortar for masonry
12-17-2010, 06:35 PM
Dear friends,
I am looking for the following standards:
EN 998-1:2010
Specification for mortar for masonry - Part 1: Rendering and plastering mortar
This European Standard is applicable to factory made rendering/plastering mortar based on inorganic binders for external (rendering) and internal (plastering) use on walls, ceilings, columns and partitions. It contains definitions and final performance requirements.
It does not cover mortars where calcium sulphate binder is the principle active binding agent.
Calcium sulphate binder can be used as an additional binder together with air lime. If air lime is the principle active binding component, the rendering/plastering mortar is covered by this European Standard. If the calcium sulphate binder is the principle active binding component, the mortar is covered by EN 13279. The classification is carried out by the producer of the mortar.
Special fire resistant- and acoustical mortars, mortars for structural repair and surface treatments of building elements such as materials for smoothing or trueing, paints, coatings, thin-layer organic renders/plasters and prefabricated units (e.g. plaster boards) are not dealt with in this European Standard.
This European Standard covers rendering/plastering mortars defined in Clause 3 with the exception of site made rendering/plastering mortars. However, this European Standard or part of this European Standard may be used in conjunction with codes of application and national specifications covering site made mortars.
EN 998-2:2010
Specification for mortar for masonry - Part 2: Masonry mortar
This European Standard specifies requirements for factory made masonry mortars (bedding, jointing and pointing) for use in masonry walls, columns and partitions (e.g. facing and rendered masonry, load bearing or non-load bearing masonry structures for building and civil engineering).
This European Standard defines for fresh mortars the performance related to workable life, chloride content, air content, density and correction time (for thin-layer mortars only). For hardened mortars it defines e.g. performances related to compressive strength, bond strength, density measured according to the corresponding test methods contained in separate European Standards.
This European Standard provides for the evaluation of conformity of the product to this European Standard.
The marking requirement for products covered by this European Standard is included.
This European Standard covers masonry mortars defined in Clause 3 with the exception of site made mortars. However, this European Standard or part of this European Standard may be used in conjunction with codes of applications and national specifications covering site made mortars.
If somebody of you have them, please share them.
Thanks in advance.
[-] The following 1 user Likes ir_71's post:1 user Likes ir_71's post
  • oreslaw
 hich
User ID: 3732
Threads: 93
Likes: 5,003 in 418 posts
Given Likes: 101
12-18-2010, 06:50 AM (This post was last modified: 01-26-2012, 09:02 AM by 3fan.)
are these what are you looking for:
[-] The following 8 users Like hich's post:8 users Like hich's post
  • Dell_Brett, kowheng, ir_71, usman, datagap, st77bel, sasan7351, oreslaw
12-18-2010, 07:14 AM
Dear hich,
I am looking for the official editions of these two standards from November 2010. Two documents, which are uploaded by you are final drafts.
I suppose there are no considerable differences between the final drafts and the final editions.
Thank you very much.
Regards.
 medo_sk
Macedonia
User ID: 18907
Threads: 68
Likes: 108 in 43 posts
Given Likes: 63
01-26-2012, 08:45 AM
The links are dead.
Please re-upload them.
  [REQUEST] EN 459-1 and 2:2010 Building lime ir_71 2 2,369 07-27-2018, 01:25 AM
Last Post: concreteok
  [REQUEST] JGJ 7-2010 Technical Specification for Space Frame Structure yanburak 2 2,550 05-22-2018, 10:20 AM
Last Post: sabooryan
  [REQUEST] A Gypsum Mortar for Small-Scale Models Grunf 1 1,871 07-03-2017, 12:52 PM
Last Post: mahyarov
  [REQUEST] BS EN 1536:2010 peixoto 4 3,083 05-13-2017, 01:22 PM
Last Post: Dell_Brett
  [REQUEST] Aluminum Design Manual - 2010 asim99 1 2,228 04-06-2016, 05:16 PM
Last Post: shaker
  [REQUEST] GB 50011-2010 chinese code ozgur 0 1,325 08-31-2014, 05:59 PM
Last Post: ozgur
  [REQUEST] Please upload BS 5974:2010 malee 2 1,762 05-25-2014, 05:59 AM
Last Post: Mohammad6299
