Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] ASCE - Adaptive Modal Combination Procedure for Nonlinear Static Analysis of Building
[Request] ASCE - Adaptive Modal Combination Procedure for Nonlinear Static Analysis of Building
 Fem.Ing
User ID: 18012
Threads: 18
Likes: 26 in 13 posts
Given Likes: 49
12-09-2010, 10:46 AM
Hi, I'm looking for this paper:
Adaptive Modal Combination Procedure for Nonlinear Static Analysis of Building Structures
Erol Kalkan, Sashi K. Kunnath
ASCE J. Struct. Engrg.
Volume 132, Issue 11, pp. 1721-1731 (November 2006)
Hope this help other users.
Thanks in advance.
[-] The following 1 user Likes Fem.Ing's post:1 user Likes Fem.Ing's post
  • rezart
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
12-09-2010, 12:22 PM
Dear user
Get it from below:
regards
[-] The following 3 users Like ssobhan's post:3 users Like ssobhan's post
  • sasan7351, rkce, Fem.Ing
 momo2010
User ID: 22358
Threads: 0
Likes: 2 in 1 posts
Given Likes: 219
12-09-2010, 01:47 PM (This post was last modified: 12-09-2010, 03:25 PM by Dell_Brett.)
Hi Dear friend,
I put the needed paper at this site:
best regards
[-] The following 2 users Like momo2010's post:2 users Like momo2010's post
  • Fem.Ing, sasan7351
09-04-2013, 08:47 AM
Author: Erol Kalkan, S.M.ASCE ; and Sashi K. Kunnath, M.ASCE | Size: 0.37 MB | Format: PDF | Quality: Unspecified | pages: 2006
[Image: 21077286432650489442.png]
A new pushover analysis procedure derived through adaptive modal combinations .AMC. is proposed for evaluating the
seismic performance of building structures. The methodology offers a direct multimode technique to estimate seismic demands and
attempts to integrate concepts built into the capacity spectrum method recommended in ATC-40 .1996., the adaptive method originally
proposed by Gupta and Kunnath .2000. and the modal pushover analysis advocated by Chopra and Goel .2002.. The AMC procedure
accounts for higher mode effects by combining the response of individual modal pushover analyses and incorporates the effects of varying
dynamic characteristics during the inelastic response via its adaptive feature. The applied lateral forces used in the progressive pushover
analysis are based on instantaneous inertia force distributions across the height of the building for each mode. A novel feature of the
procedure is that the target displacement is estimated and updated dynamically during the analysis by incorporating energy-based modal
capacity curves in conjunction with constant-ductility capacity spectra. Hence it eliminates the need to approximate the target displacement
prior to commencing the pushover analysis. The methodology is applied to two existing steel moment-frame buildings and it is
demonstrated that the AMC procedure can reasonably estimate critical demand parameters such as roof displacement and interstory drift
for both far-fault and near-fault records, and consequently provides a reliable tool for performance assessment of building structures.
  • Dell_Brett, malc, kowheng, mgdario, andersen3, ruaumoko
  [REQUEST] 3DPUSHOVER 2008 - NONLINEAR STATIC METHODS FOR DESIGN/ASSESSMENT OF 3D STRUCTURES ibmarin 2 2,251 08-19-2014, 01:23 PM
Last Post: rigid_joint
  [REQUEST] Nonlinear Analysis of Stress and Strain in Soils ch_surf 0 1,397 07-15-2014, 10:07 PM
Last Post: ch_surf
  [REQUEST] Analysis of geometrically nonlinear structures Robert Levy,William R. Spillers xuanmoon 2 2,360 06-26-2014, 05:13 PM
Last Post: ssobhan
  [REQUEST] Adaptive Stress Field Models: Formulation and Validation Mohammad6299 1 1,607 05-25-2014, 01:46 PM
Last Post: nima_b12
  [REQUEST] Nonlinear analysis of collape load of P/C cable stayed bridge netsonicyxf 1 1,508 05-02-2014, 03:03 PM
Last Post: Mohammad6299
  [REQUEST] PHD Thesis - Static analysis of cable stayed bridges netsonicyxf 0 1,306 05-02-2014, 07:28 AM
Last Post: netsonicyxf
  [REQUEST] Nonlinear dynamic analysis of three dimensional base isolated structures ali akbar 0 1,361 03-08-2014, 03:14 PM
Last Post: ali akbar
