Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 996:1995+A3:2009 Piling equipment - Safety requirements
11-14-2010, 03:09 PM
1.1 This standard specifies safety requirements for piling equipment suitable for the following purposes:
a) Construction of foundations, slurry walls or retaining walls, using piles or other longitudinal elements;
b) Removal of piles;
c) Installation of drain or injection elements.
The pile material can be timber, concrete (precast or cast in situ) or steel (tubes or rolled sections). Additionally, piles may have an interlocking feature to enable adjacent piles to be joined together.
1.2 This European standard deals with all significant hazards pertinent to piling equipment, when they are used as intended and under the conditions foreseen by the manufacturer (see annex A) associated with the following:
- Transport of equipment;
- Rigging and dismantling of equipment;
- Equipment in service and out of service;
- Moving of equipment between pile positions;
- Storage of equipment.
This European Standard specifies the appropriate technical measures to eliminate or reduce risks arising from the significant hazards.
1.3 Piling equipment includes:
a) Piling rig consisting of carrier machine (crawler, wheel or rail mounted, floating), leader attachment, leader or other guiding systems, e.g. direct mounted, boom supported, swinging, guide cage or free riding;
b) Pile installation and extraction equipment, e.g. impact hammers, extractors, vibrators or static pile pushing/pulling devices;
c) Accessories, e.g. pile caps, helmets, plates, followers, clamping devices, pile handling devices, pile guides, acoustic shrouds and shock/vibration absorbing devices, power packs/generators and personnel lifts or platforms.
1.4 In addition, this standard applies to diaphragm walling rigs. Additionally, the particular requirements which apply to diaphragm walling equipment are given in normative annex C.
  • Dell_Brett, kowheng, zrilek, Grunf, oanm2000, peixoto, roaming79, dbsimon29, asim99
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
02-14-2013, 01:11 PM
link dead; reposted here:
pass:
[-] The following 2 users Like andersen3's post:2 users Like andersen3's post
  • Dell_Brett, asim99
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,709 in 1,305 posts
Given Likes: 4621
10-01-2020, 07:04 AM
EN 996:1995+A3:2009
[-] The following 9 users Like lisine's post:9 users Like lisine's post
  • blaze, zrilek, Dell_Brett, babakfeyzi, CAMSECT, oanm2000, PinkPant, Wijono, kowheng
  EN 12352:2006 Traffic control equipment - Warning and safety light devices ir_71 0 1,712 03-29-2011, 06:07 PM
