Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 15237:2007 Execution of special geotechnical works - Vertical drainage
11-14-2010, 06:21 AM
This European Standard establishes general principles for the execution, testing, supervision and monitoring of vertical drain projects.
This European Standard includes the application of prefabricated vertical drains and sand drains and deals with requirements to be placed on design, drain material and installation methods. This European Standard applies to the improvement of low-permeability, highly compressible soils by vertical drainage and preloading. Information regarding loading (embankment, vacuum or ground water lowering) and preloading is given in informative Annexes A and B.
Vertical drainage is used both in on land and in marine constructions for the following purposes:
п‚ѕ (pre-)consolidation and reduction of post-construction settlements;
п‚ѕ speeding up the consolidation process by decreasing the path lengths for pore water dissipation;
п‚ѕ increase of stability (by increasing effective stresses in the soil);
п‚ѕ groundwater lowering;
п‚ѕ mitigation of liquefaction effects.
In each case there is an overall treatment of the soil (the volume of the drains is small in relation to the soil volume treated).
This European Standard does not include soil improvement by means of wells, gravel and stone columns, large-diameter geotextile enclosed columns or reinforcing elements.
Vertical drainage can also be combined with other foundation or ground improvement methods, e.g. electro osmosis, piles and compacted sand piles, dynamic compaction and deep mixing.
Guidance on practical aspects of vertical drainage, such as investigation of drain properties, execution procedures and equipment, is given in Annex A. Investigation of soil characteristics and assessment of design parameters, which are affected by drain properties and execution, are presented in Annex B.
:JC_cheers:
  • kowheng, avscorreia, Dell_Brett, piseth, jcoronellr, toa011, zrilek, Grunf, oanm2000, Raktim, roaming79, dede, techno, vvvv, kaci, serhioSPA
 st77bel
Romania
User ID: 12964
Threads: 16
Likes: 432 in 86 posts
Given Likes: 696
11-03-2012, 04:44 PM (This post was last modified: 11-03-2012, 07:11 PM by 3fan.)
New working link for BS EN 15237:2007:
[-] The following 11 users Like st77bel's post:11 users Like st77bel's post
  • 3fan, Dell_Brett, cace-01, zrilek, utan, blaze, uetian19, serhioSPA, Hengki, rizal13, CAMSECT
  EN 14199:2005 Execution of special geotechnical works - Micropiles ir_71 4 5,823 03-03-2022, 08:55 AM
Last Post: concreteok
  EN 12715:2000 Execution of special geotechnical work - Grouting ir_71 3 4,660 06-29-2020, 04:12 AM
  EN 12716:2001 Execution of special geotechnical works - Jet grouting ir_71 4 5,139 06-29-2020, 02:54 AM
  EN 14475:2006 Execution of special geotechnical works - Reinforced fill ir_71 1 2,699 10-27-2012, 07:55 AM
Last Post: st77bel
  EN 12699:2000 Execution of special geotechnical work - Displacement piles ir_71 4 4,262 09-20-2012, 03:48 PM
Last Post: 3fan
