11-04-2010, 08:34 PM
BS 8000 standard series "Workmanship on building sites"
![[Image: info.png]](https://forum.civilea.com/postgen/info.png)
Contents of the package:
BS 8000-1:1989 Workmanship on building sites. Code of practice for excavation and filling
This Part of BS 8000 gives recommendations on basic workmanship on building sites and covers those tasks which are frequently carried out in relation to excavating and filling.
This code of practice does not cover civil engineering works for which reference should be made to BS 6031.
BS 8000-3:1989 Workmanship on building sites. Code of practice for masonry
BS 8000-4:1989 Workmanship on building sites. Code of practice for waterproofing
This Part of BS 8000 gives recommendations on basic workmanship on building sites and covers those tasks which are frequently carried out in relation to waterproofing.
For design aspects of waterproofing reference should be made to CP 102 and CP 144-3 and CP 144-4.
BS 8000-6:1990 Workmanship on building sites. Code of practice for slating and tiling of roofs and claddings
This Part of BS 8000 gives recommendations on basic workmanship and covers those tasks which are frequently carried out in relation to slating and tiling of roofs and claddings of buildings.
The recommendations apply to the laying and fixing of clay and concrete tiles; natural and fibre reinforced cement slates and their associated fittings and accessories.
For design aspects of slating and tiling reference should be made to BS 5534-1 and BS 5534-2.
BS 8000-7:1990 Workmanship on building sites. Code of practice for glazing
This part of BS 8000 gives recommendations on basic workmanship on building sites and covers those tasks which are frequently carried out in relation to glazing.
This code does not cover off-site glazing (e.g. factory glazing), specialist glazing techniques or systems (e.g. patent glazing), specialist applications (e.g. greenhouses and barriers/balustrades), roof glazing and glazing of furniture and fittings. Additionally it does not apply to bent, profiled and corrugated glass/plastics sheet material, or to glass blocks or lens lights.
For design aspects of glazing, including safety, reference should be made to BS 6262.
BS 8000-8:1994 Workmanship on building sites. Code of practice for plasterboard partitions and dry linings
This Part of BS 8000 gives recommendations on basic workmanship and covers those tasks which are frequently carried out in relation to plasterboard partitions and dry linings.
For design aspects of plasterboard partitions and dry linings reference should be made to BS 5234-1.
BS 8000-9:2003 Workmanship on building sites. Cementitious levelling screeds and wearing screeds. Code of practice
This part of BS 8000 provides recommendations on laying cementitious levelling screeds and wearing screeds. It makes recommendations and gives guidance on basic workmanship for conventional types of building work.
The main changes in this British Standard from the previous edition take account of the following.
a) The terms used for the types of screeds take account of developments in European standardization. Screeds are designated “levelling screeds” where they are to receive a final flooring and “wearing screeds” where they serve to provide the finished surface.
b) Bases to carry rigid insulation boards beneath floating screeds are to be levelled by filling depressions so that the boards do not rock on high spots.
c) The specifications for materials have been updated. In particular European Standard specifications for cements now include a number of cement types and standard strength classes.
d) The use of higher slag content cements (>35%) and the equivalent combinations have been excluded from levelling screeds due to limited experience of their use.
e) The bags of cement now supplied by the manufacturers have been halved in weight to 25 kg so mix calculations have been modified.
f) Slurry bonding of the edges of day work joints is recommended before laying fresh screed material to help reduce curling at butt joints.
g) Items of work to be checked during progress, as well as on the finished screed, are listed.
h) The recommendations given in BS 8204-1 and BS 8204-2 are referred to for curing when using cement lower than strength class 42.5 N.
BS 8000-10:1989 Workmanship on building sites. Code of practice for plastering and rendering
BS 8000-11.1:1989 Workmanship on building sites. Code of practice for wall and floor tiling. Ceramic tiles, terrazzo tiles and mosaics
This Section of BS 8000 gives recommendations on basic workmanship on building sites and covers those tasks which are frequently carried out in relation to wall and floor tiling.
The recommendations given in this Section of BS 8000 apply to the fixing of ceramic tiles and mosaics to walls and floors and to the fixing of terrazzo tiles to floors. The fixing of natural stone is covered in Section 11.2 of BS 80001).
Design aspects of wall and floor tiling are given in BS 5385 and CP 202.
BS 8000-12:1989 Workmanship on building sites. Code of practice for decorative wallcoverings and painting
This Part of BS 8000 gives recommendations on basic workmanship on building sites and covers those tasks which are frequently carried out in relation to decorative wallcoverings and painting.
For other aspects of decorative wallcoverings and painting reference should be made to BS 3046, BS 5493 and BS 6150.
BS 8000-13:1989 Workmanship on building sites. Code of practice for above ground drainage and sanitary appliances
This Part of BS 8000 gives recommendations on basic workmanship and covers those tasks which are frequently carried out in relation to above ground drainage and sanitary appliance installation.
For design aspects of above ground drainage and sanitary appliance installation reference should be made to BS 5572, BS 6367 and BS 6465-1.
BS 8000-14:1989 Workmanship on building sites. Code of practice for below ground drainage
This Part of BS 8000 gives recommendations on basic workmanship on building sites and covers those tasks which are frequently carried out in relation to below ground drainage.
For design and special aspects of below ground drainage reference should be made to BS 8301.
BS 8000-15:1990 Workmanship on building sites. Code of practice for hot and cold water services (domestic scale)
This Part of BS 8000 gives recommendations on basic workmanship and covers those tasks which are frequently carried out in relation to hot and cold water services (domestic scale).
For design aspects of hot and cold water services, reference should be made to BS 6700.
BS 8000-16:1997 Workmanship on building sites. Code of practice for sealing joints in buildings using sealants
This Part of BS 8000 gives recommendations on basic workmanship on building sites and covers those tasks which are frequently carried out in relation to sealant application. For design aspects of joints, reference should be made to BS 6093 and BS 6213.
:JC_cheers:
![[Image: Download.png]](https://forum.civilea.com/postgen/Download.png)
![[Image: password.png]](https://forum.civilea.com/postgen/password.png)
