Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 545:2010 Ductile iron pipes, fittings, accessories and their joints for water pipe
11-03-2010, 01:26 AM
EN 545:2010 Ductile iron pipes, fittings, accessories and their joints for water pipelines. Requirements and test methods
This European Standard specifies the requirements and associated test methods applicable to ductile iron
pipes, fittings, accessories and their joints for the construction of pipelines outside buildings:
 to convey different types of water (e.g. raw water, treated water, re-used water) for all types of
applications (e.g. water intended for human consumption, for fire protection, for snow making, for
irrigation, for hydro-electricity etc.);
 with or without pressure;
 to be installed below or above ground.
This European Standard is applicable to pipes, fittings and accessories which are:
 manufactured with socketed, flanged or spigot ends;
 supplied externally and internally coated;
 suitable for fluid temperatures between 0 °C and 50 °C, excluding frost;
 not intended for use in areas subject to reaction to fire regulations.
This does not preclude special arrangements for the products to be used at higher temperatures.
This European Standard covers pipes and fittings cast by any type of foundry process or manufactured by
fabrication of cast components, as well as corresponding joints and accessories, in a size range extending
from DN 40 to DN 2 000, inclusive.
This European Standard specifies requirements for materials, dimensions and tolerances, mechanical
properties and standard coatings of ductile iron pipes and fittings. It also gives performance requirements for
all components including joints. Joint design and gasket shapes are outside the scope of this standard.
In addition, reference is made to the minimum performance requirements of couplings, flange adaptors and
saddles manufactured for use with ductile iron pipes and fittings.
NOTE In this European Standard, all pressures are relative pressures, expressed in bars (100 kPa = 1 bar).
:JC_cheers:
  • kowheng, ashcivilea, Grunf, hmwere, roaming79, toa011, chenamoy, Dell_Brett, k1k0k0
12-24-2010, 07:58 AM
Author: CEN/TC 203 | Size: 1 MB | Format: PDF | Publisher: CEN | Year: 2010 | pages: 98 | ISBN: 978 0 580 69790 6
[Image: 62826409243088562232.jpg]
Dear friends,
Please, accept my best wishes for Christmas and the coming new year 2011.
  • Grunf, Dell_Brett, kowheng, ashcivilea, usman, k1k0k0
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
07-17-2014, 08:36 AM
this standard was also posted at
new lworking inks
password
[-] The following 2 users Like andersen3's post:2 users Like andersen3's post
  • Mohammad6299, malc
  EN 1916 Concrete pipes and fittings, unreinforced, steel fibre and reinforced datagap 4 5,105 02-13-2022, 11:44 AM
  EN 1092 Flanges and their joints — Circular flanges for pipes, valves, fittings and a ir_71 1 2,322 05-14-2015, 01:50 PM
Last Post: PinkPant
