Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 2573
BS 2573
 surajdas
User ID: 5954
Threads: 6
Likes: 27 in 7 posts
Given Likes: 271
Points:746 EP
10-26-2010, 04:49 PM (This post was last modified: 11-03-2010, 09:04 AM by Grunf.)
BS 2573-1:1983
Rules for the design of cranes. Specification for classification, stress calculations and design criteria for structures
Status CU
Publication Date 31/10/83
Committee MHE/3
ISBN 0 580 13385 0
Pages 74
International Equivalent
Descriptors:
Cranes, Lifting equipment, Design, Structural design, Classification systems, Loading, Safe working load, Formulae (mathematics), Design calculations, Gantry cranes, Jib cranes, Derricks, Mobile cranes, Wind loading, Climatic loading, Construction materials, Steels, Thickness, Working stress, Stress, Structural members, Struts, Stress analysis, Shear stress, Welded joints, Studs (fasteners), Bolts, Rivets, Bolting, Beams, Girders, Tensile stress, Fatigue, Axial stress, Tower cranes, Length, Dimensions, Buckling, Flanges, Box girders, Mechanical components, Designations
Cross references:
BS 4:Part 1, BS 153, BS 449:Part 2, BS 639, BS 709, BS 2573:Part 2, BS 2853, BS 4360, BS 4395:Part 1, BS 4395:Part 2, BS 4395:Part 3, BS 4604:Part 1, BS 4604:Part 2, BS 4604:Part 3, BS 4848:Part 4, BS 5135
Replaced By BS EN 13001-1:2004 BS EN 13001-2:2004 DD CEN/TS 13001-3.1:2004 DD CEN/TS 13001-3-2:2004
Replaced by Notes:
BS EN 13001-1:2004, BS EN 13001-2:2004, DD CEN/TS 13001-3.1:2004 and DD CEN/TS 13001-3-2:2004 but remains current until part 3-3 of the series is published.
BS 2573-2:1980
Rules for the design of cranes. Specification for classification, stress calculations and design of mechanisms
Status CU
Publication Date 31/12/80
Committee MHE/3
ISBN 0 580 11763 4
Pages 24
Descriptors:
Cranes, Lifting equipment, Design, Structural design, Stress, Design calculations, Loading, Classification systems, Designations, Working stress, Loading, Axial stress, Shear stress, Bending stress, Shafts (rotating), Bearings, Gear drives, Breaking load, Ropes, Hoisting drums, Pulleys, Wheels, Bearing stress, Bolts, Fatigue, Stress concentration, Hooks, Lifting tackle, Life (durability), Mechanical components, Torque
Cross references:
BS 436, BS 545, BS 721, BS 970, BS 1134, BS 2573:Part 1, BS 2903, BS 3017, BS 3037, BS 3579, BS 3692, BS 5512:Part 1, ISO 2408, ISO 4301, ISO 4308, ISO 4309
Replaced By:
Replaced by notes:
Moderator note:
Info added. Thread moved from Request Section to Codes, Manual & Handbook Section. (G)
[-] The following 1 user Likes surajdas's post:1 user Likes surajdas's post
  • pssst
Points:178,871 EP
10-26-2010, 05:04 PM (This post was last modified: 01-22-2011, 02:53 PM by Dell_Brett.)
Hi, surajdas.
Requested standards are here:
BS 2573-1
and
BS 2573-2
  • Grunf, cordoba123, ziggywas1, lasalleguy, Dell_Brett, kowheng, ssi3k, jcbv, roaming79, surajdas, zrilek, dert, blaze, oanm2000, pssst
Points:178,871 EP
01-22-2011, 06:22 PM
Author: Committee MHE/3/1 | Size: 3.86 MB | Format: PDF | Publisher: BSI | Year: 1983 | pages: 72 | ISBN: 0580133850
[Image: 48083175097835666438.jpg]
This British Standard, a part of the BS 2573 series, specifies the basis for computing stresses in crane structures and the way in which permissible stresses in crane structures are determined in order to secure economy in design and reliability in operation. For this purpose it specifies a classification system that enables the purchaser and the manufacturer to match a particular crane to the required duty and utilization.
This standard covers the classification of crane; loads and load combinations; selection of steel, minimum thickness and working stresses; stresses in structural components; basic stresses in connections; proportions of structural components, plates and web stiffeners; and permissible fatigue stresses.
[-] The following 19 users Like ir_71's post:19 users Like ir_71's post
  • Grunf, blaze, oanm2000, lasalleguy, usman, techno, Dell_Brett, kowheng, dinu69in, ashcivilea, zrilek, surajdas, mahfuzbangla, dbsimon29, eng-bg2009, duazo2009, Umer.Aleem, Nilupa, nowanda
 arshiakh
User ID: 37777
Threads: 100
Likes: 3,224 in 617 posts
Given Likes: 214
Points:27,526 EP
02-22-2013, 03:40 PM
BS 2573-1:1983
BS 2573-2:1980
[-] The following 3 users Like arshiakh's post:3 users Like arshiakh's post
  • Dell_Brett, peixoto, chenamoy
