Civil Engineering Association eBooks Traffic Engineering Thesis - Laboratory Characterisation of Pavement Foundation Materials
 cace-01
User ID: 15651
Threads: 440
Likes: 10,522 in 867 posts
Given Likes: 7468
10-23-2010, 12:35 PM (This post was last modified: 04-18-2012, 04:15 AM by usman.)
[Image: 36844792363867898366.jpg]
Laboratory Characterisation of Pavement Foundation Materials - Jonathan Paul Edwards
Doctoral Thesis
Loughborough University
March 2007
ABSTRACT
Pavement foundations for major roads in the UK were historically designed on an empirical
basis, related to a single design chart, restricting the incorporation of superior performing
materials or materials for which the empirical data sets were not available. The adoption of
performance based specifications was promoted as they are perceived to ‘open up’ the use of
alternative materials (including ‘local’ sources of primary materials) or techniques, and allow for
the incorporation of superior performance into the overall pavement design. Parallel
developments to the performance based design of pavement foundations (allowing for superior
performance) and in situ testing required the support of laboratory based performance tests.
These laboratory based tests were required to determine material performance parameters
(elastic modulus and resistance to permanent deformation) for both unbound and hydraulically
bound pavement foundation materials. A review of the available laboratory apparatus indicated
that they were either; unrealistic (and hence unable to provide the required material
performance parameters), or overly complex and more suited to fundamental research.
Therefore, the requirement for developmental research work was identified. The research
reported herein details the development, manufacture and initial evaluation of simplified
laboratory apparatus (the Springbox for unbound materials and static stiffness test for
hydraulically bound mixtures) designed to produce the performance parameters of elastic
modulus and relative resistance to permanent deformation for pavement foundation materials.
The equipment and test procedure evaluation was undertaken across a range of materials,
giving initial guidance on likely in situ performance.
The innovative laboratory apparatus and materials guidance (including the potential to use
recycled and secondary aggregates) was incorporated into key Highways Agency specification
and guidance documents, which in turn influence construction practice outside of motorways
and major trunk roads. This research concludes by outlining a number of recommendations for
continued development and evaluation, including feeding back data sets from long term in situ
performance testing for subsequent refinement of assumptions.
[-] The following 10 users Like cace-01's post:10 users Like cace-01's post
  • utan, kowheng, toa011, Administrator , Dell_Brett, husni02, cigutierrezg, fer962933, lisine, uetian19
  [REQUEST] Pavement Design: Materials, Analysis, and Highways cace-01 1 3,259 10-21-2020, 05:55 PM
Last Post: oonan
  Pavement Design and Materials toa011 5 6,386 11-04-2019, 01:21 AM
  Advances in Pavement Design through Full-scale Accelerated Pavement Testing cace-01 4 2,860 01-26-2015, 03:50 AM
Last Post: gulilero
  Paving Materials and Pavement Analysis (GSP 203) hich 2 4,147 10-22-2014, 03:32 PM
Last Post: hessi
  Estimating Stiffness of Subgrade and Unbound Materials for Pavement Design mahyarov 0 1,887 10-25-2012, 08:57 PM
Last Post: mahyarov
  Contributions of Pavement Structural Layers to Rutting of Hot-Mix Asphalt Pavement mahyarov 0 1,609 10-24-2012, 10:59 AM
Last Post: mahyarov
  USDOT - Integrated Materials and Construction Practices for Concrete Pavement Dell_Brett 1 2,450 10-19-2010, 07:12 AM
