Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Thermoelastic stability of trusses with temperature-dependent constitutive relations
[Request] Thermoelastic stability of trusses with temperature-dependent constitutive relations
 pankotso
User ID: 20549
Threads: 17
Likes: 16 in 2 posts
Given Likes: 13
10-22-2010, 09:51 AM (This post was last modified: 10-22-2010, 03:15 PM by Dell_Brett.)
Hi guys,
I am looking for a paper for some time but I do not have access to it. If you have access to it please share. The paper is P. Wriggers, S. Reese, Thermoelastic stability of trusses with temperature-dependent constitutive relations, International Journal for Numerical Methods in Engineering 35 (1992), 1891-1906. Thank a lot! Cu
 hich
User ID: 3732
Threads: 93
Likes: 5,003 in 418 posts
Given Likes: 101
10-24-2010, 09:55 AM (This post was last modified: 10-25-2010, 06:28 AM by Grunf.)
here it is
post approved by moderator
[-] The following 4 users Like hich's post:4 users Like hich's post
  • kowheng, pankotso, surajdas, jcbv
 pankotso
User ID: 20549
Threads: 17
Given Likes: 13
10-27-2010, 03:52 PM
Hi thanks a lot, I am also looking for another paper called: The thermal loads in the finite element analysis of elasto-plastic stresses by A. Grill1 K. Sorimachi in International Journal for Numerical Methods in Engineering Volume 14, Issue 4, pages 499–505, 1979. Do you have access to that? Thanks a lot in advance.
 hich
User ID: 3732
Threads: 93
Given Likes: 101
10-27-2010, 05:41 PM (This post was last modified: 10-28-2010, 08:02 AM by Grunf.)
here
[-] The following 2 users Like hich's post:2 users Like hich's post
  • pankotso, Dell_Brett
 pankotso
User ID: 20549
Threads: 17
Given Likes: 13
10-28-2010, 02:37 PM
Hi hich you are great thanks for all this help. Can you also try to help with another 3 papers from the same journal.
Elasto-plastic solutions of engineering problems ‘initial stress’, finite element approach
Improved stress evaluation under thermal load for simple finite elements
A study of incremental-iterative strategies for non-linear analyses
Thanks a lot for all the help in advance!!
 hich
User ID: 3732
Threads: 93
Given Likes: 101
10-30-2010, 09:45 PM
here
  • Dell_Brett, pankotso
  [REQUEST] Time Dependent and Nonlinear Effects in Polymers and Composites Mohammad6299 0 1,282 09-09-2014, 04:45 PM
Last Post: Mohammad6299
  [REQUEST] Equivalent Beam Method for Trusses shadysherief 0 1,331 02-09-2013, 08:31 PM
Last Post: shadysherief
  [REQUEST] Design of Composite Trusses deviationz 2 2,492 11-16-2012, 12:44 PM
  [REQUEST] The return mapping method for the integration of friction constitutive relations freequo 1 1,461 05-16-2012, 02:07 PM
Last Post: ynopum
  [REQUEST] A large triaxial investigation of the stress-path-dependent behavior of compacted roc freequo 1 1,583 05-10-2012, 08:53 AM
Last Post: cace-01
  [REQUEST] Nonlinear time dependent design and analysis of slender reinforced concrete columns galcik 1 1,854 03-01-2012, 04:06 PM
Last Post: zeljko2
  [REQUEST] Time-dependent deformations and stresses in prestressed concrete structures alex4000 0 1,440 10-17-2011, 12:41 PM
Last Post: alex4000
