Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] foundation design with uplift
[Request] foundation design with uplift
 rohailiyaz
User ID: 925
Threads: 146
Likes: 1,152 in 117 posts
Given Likes: 733
10-21-2010, 10:51 AM (This post was last modified: 01-16-2012, 11:24 PM by Grunf.)
can anyone provide some guidelines or excel sheet or any material regarding footing design with uplift(for steel structures).
i know there are many spread sheets available but most of them don't incorporate the effect of uplift
 visu
User ID: 19389
Threads: 11
Likes: 447 in 180 posts
Given Likes: 377
10-21-2010, 11:16 AM
I dont see any Excel sheet for the foundation uplift.
1. Use SAFE or PCA mats for uplift problem.
2. If you designing isolated footing and the uplift is due to the moment from the column you can use RISA foot.
3. RCC spread sheet does not consider uplift.
[-] The following 1 user Likes visu's post:1 user Likes visu's post
  • Grunf
 jaks
User ID: 2764
Threads: 15
Likes: 258 in 54 posts
Given Likes: 1225
10-21-2010, 11:23 AM (This post was last modified: 08-16-2011, 08:21 PM by Grunf.)
Below is a excel sheet I prepared for the footing with uplift, I hope will help your cause.
Please check the output, and revert if any bugs/corrections needed. The sheet designs to BS-8110.
Jaks
[-] The following 6 users Like jaks's post:6 users Like jaks's post
  • kowheng, Administrator , rohailiyaz, isurya, Dell_Brett, ruaumoko
 jaks
User ID: 2764
Threads: 15
Given Likes: 1225
10-21-2010, 11:51 AM (This post was last modified: 08-16-2011, 08:22 PM by Grunf.)
@ aslam
Even prokon footing design module can do the needful with uplift loads entered (just in case).
[-] The following 5 users Like jaks's post:5 users Like jaks's post
  • rendel_©, isurya, aslam, kaungthant, Dell_Brett
  [REQUEST] Bearing Pressures for Rectangular Footings with Biaxial Uplift- Request ali akbar 2 3,111 06-08-2014, 11:15 AM
Last Post: sia1
  [REQUEST] Influence of uplift on liquid storage tanks during earthquakes ssobhan 0 1,232 03-11-2013, 07:56 PM
Last Post: ssobhan
