Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 10080 - Steel for the reinforcement of concrete
10-21-2010, 06:43 AM (This post was last modified: 10-21-2010, 06:58 AM by Grunf.)
May 2005
English version
Steel for the reinforcement of concrete - Weldable reinforcing
steel - General
Description:
BS EN 10080:2005
Weldable steel for the reinforcement of concrete has become subject to the European Standard, BS EN 10080. This standard went back and forth over many years seeking a pragmatic agreement amongst Europeans on how to standardise reinforcement. In other words, it has taken a long time to move from being a mandated standard (one that the European Commission asked CEN to prepare) to being a harmonised standard. In 2008 it had to be withdrawn as a harmonized standard because some countries legal requirements for additional proprties of reinforcement were not met. However, it was implemented in the UK in late 2005 and its subsequent withdrawl has no effect on BS 4449 etc.
BS EN 10080:2005 gives no actual specification or figures that is left to the National Standards. requires that technical classes should be specified by values of:
* Re, yield strength;
* Rm/Re, Ratio of tensile strength/Yield strength,
* Agt, Percentage total elongation at maximum force,
* Re,act/Re,nom (where appropriate), Ratio of actual to specified value of yield strength,
* fatigue strength,
* bend performance,
* weldability,
* bond strength,
* tolerances and
* dimensions.
It contains an informative Annex ZA, which describes how the standard may be used for the purposes of CE marking. Please note that the CE mark is not a quality mark. It merely identifies the product as complying with the essential requirement laid down by the European Commission in their 'mandate' to CEN. CE marking is not a requirement of BS 4449:2005.
[-] The following 3 users Like Grunf's post:3 users Like Grunf's post
  • warbeast, LiviuM, ssi3k
10-21-2010, 06:50 AM
Hi, Grunf.
It is privilege for me to help you;
EN 10080
Good luck.
[-] The following 17 users Like ir_71's post:17 users Like ir_71's post
  • Grunf, bhawk0, kowheng, concreteok, Dell_Brett, hans01, vvvv, allagui10, st77bel, jferrer, roaming79, hmwere, zrilek, warbeast, Mrlac, LiviuM, ssi3k
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 50
Likes: 4,962 in 637 posts
Given Likes: 3500
10-21-2010, 07:04 AM (This post was last modified: 10-21-2010, 07:06 AM by concreteok.)
older dd env if anyone interested
concrete solution advocate
[-] The following 6 users Like concreteok's post:6 users Like concreteok's post
  • Dell_Brett, Grunf, hans01, vvvv, vardan, zrilek
 st77bel
Romania
User ID: 12964
Threads: 16
Likes: 432 in 86 posts
Given Likes: 696
05-26-2012, 12:10 PM
New link for BS EN 10080:2005:
[-] The following 16 users Like st77bel's post:16 users Like st77bel's post
  • naing.id, 3fan, Jackass, blaze, zrilek, ssi3k, knrsa, seb3k, Dell_Brett, Hengki, vvvv, miquan, junaid, fer962933, oyabun, hodzicemir
  EN ISO 15630 Standard series Steel for the reinforcement and prestressing of concrete ir_71 5 5,799 02-15-2022, 08:36 AM
Last Post: zrilek
