Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general NYDOT: MECHANICALLY STABILIZED EARTH SYSTEM INSPECTION MANUAL
 tuanpecc1
Semi Senior Member
Vietnam
User ID: 16595
Threads: 63
Likes: 1,426 in 86 posts
Given Likes: 1375
10-20-2010, 02:24 PM (This post was last modified: 01-05-2012, 08:25 PM by usman.)
[Image: 33098553450470049868.png]
Publisher: NEW YORK STATE DEPARTMENT OF TRANSPORTATION
Pages: 95
Date: April 2007
PREFACE
The purpose of this manual is to provide New Yorh State Department of Transportation Construction Inspectors with a quick and easy-to-use set of inspection guidelines for the installation of Mechanically Stabilized Earth Systems (MSES) that utilize inextensible metallic reinforcements i. e., reinforcing strips, bar mats or wire mesh. The enclosed check lists are intended to serve as reminders to inspectors of unportant aspects for the successfid construction of MSES.
Prior to using this manual, inspectors should become familiar with the general concepts of MSES. Thus information can be found in Chapters 1, 2 & 3 of the Federal Highway Administration Publication No. FHVVA-N-HI-00-043, titled "Mechanically Stabilized Earth Walls and Reinforced Soil Slopes Design and Construction Guidelines", wl-tich is included as Appendix 1 of tills manual. In addition, it is imperative that Engineers-In-Charge obtain from the Contractor and review copies of the MSES designers/suppliers Construction Manual. The MSES Designerf`Supplier's Construction Manual contains detailed fi ornlation for the construction of a particular MSES and provides the necessary guidance during the construction inspection process .
[Image: 84976297706777778314.png][Image: 50650061847242527552.png]
[-] The following 10 users Like tuanpecc1's post:10 users Like tuanpecc1's post
  • kowheng, shaqee, oanm2000, toa011, Dell_Brett, kaci, roaming79, Evandrojr, peymanlord, alibouafia
  Earth Pressure and Earth-Retaining Structures, 3th Ed. odiclas 4 3,753 06-10-2021, 07:39 AM
  Assessing the Long-Term Performance of Mechanically Stabilized Earth Walls mahyarov 0 1,504 10-24-2012, 01:27 PM
Last Post: mahyarov
  USDOT: Design and Construction of Mechanically Stabilized Earth Walls and Reinforced ir_71 3 3,396 08-18-2012, 04:33 PM
Last Post: gulilero
  Earth Pressure and Earth-Retaining Structures toa011 6 5,230 08-14-2012, 08:41 AM
Last Post: shadabg
  NYDOT: ROCK SLOPE RATING PROCEDURE tuanpecc1 0 1,951 10-20-2010, 03:31 PM
Last Post: tuanpecc1
  NYDOT: Bank and channel protective lining design procedures tuanpecc1 0 1,812 10-20-2010, 02:58 PM
  NYDOT: COMPUTATION OF SKIN FRICTION ON DRIVEN NONTAPERED PILES IN COHESIONLESS SOIL tuanpecc1 0 1,916 10-19-2010, 04:17 PM
