Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] ISO 15901-1:2005 Pore size distribution and porosity of solid materials by mercury po
[Request] ISO 15901-1:2005 Pore size distribution and porosity of solid materials by mercury po
10-18-2010, 04:41 AM
ISO 15901-1:2005 Pore size distribution and porosity of solid materials by mercury porosimetry
ISO 15901-1:2005 describes a method for the evaluation of the pore size distribution and the specific surface in pores of solids by mercury porosimetry according to the method of Ritter and Drake. ISO 15901-1:2005 describes a comparative test, usually destructive due to mercury contamination, in which the volume of mercury penetrating a pore or void is determined as a function of an applied hydrostatic pressure, which can be related to a pore diameter.
Practical considerations presently limit the maximum applied absolute pressure to about 400 MPa (60 000 psia) corresponding to a minimum equivalent pore diameter of approximately 0,003 m. The maximum diameter is limited for samples having a significant depth due to the difference in hydrostatic head of mercury from the top to the bottom of the sample. For the most purposes, this limit can be regarded as 400 m. ISO 15901-1:2005 applies to inter-particle and intra-particle porosity but cannot distinguish between these porosities where they co-exist.
ISO 15901-1:2005 is suitable for the study of most non-wettable, by mercury, porous materials. Samples that amalgamate with mercury, such as certain metals, e.g. gold, aluminium, reduced copper, reduced nickel and silver, can be unsuitable for this technique or can require a preliminary passivation.
FORMAT: 36 pages, A4
ISBN: 978 0 580 55281 6
Dear friends and colleagues,
It is clear the standard mentioned above is quite specific, but if some of you has it, please share it.
Thanks in advance!
IR
  [REQUEST] Pore structure of cement-based materials : testing interpretation & requirements ir_71 1 2,140 11-21-2016, 09:44 PM
Last Post: inge911
  [REQUEST] A simplified method of estimating construction pore pressures in earth dams rilxous 0 1,237 07-30-2014, 03:22 AM
Last Post: rilxous
  [REQUEST] Effect of Sample Size on the Behavior of Granular Materials freequo 1 1,634 01-27-2012, 03:12 PM
Last Post: hich
  [REQUEST] ISO 1920-10 and ISO 15901-1 ir_71 1 1,657 02-19-2011, 07:19 PM
Last Post: melkat
