Civil Engineering Association eBooks Structural Books Concrete Experimental and Theoretical Investigations of Steel-Fibrous Concrete
 cargadory2k
Mexico
User ID: 3043
Threads: 80
Likes: 851 in 108 posts
Given Likes: 346
10-11-2010, 02:44 PM
Experimental and Theoretical Investigations of Steel-Fibrous Concrete ( Series in Geomechanics and Geoengineering) Jacek Tejchman, Jan Kozicki
[Image: 64176503559137736634.jpg]
Publisher: Springer
ISBN 3642146023 Year: 2010
PDF 291 pages 11.9 MB
Concrete is still the most widely used construction material since it has the lowest ratio between cost and strength as compared to other available materials. However, it has two undesirable properties, namely: low tensile strength and large brittleness that cause the collapse to occur shortly after the formation of the first crack. To improve these two negative properties and to achieve a partial substitute of conventional reinforcement, an addition of short discontinuous randomly oriented steel fibres can be practiced among others. In spite of positive properties, fibrous concrete did not find such acknowledgment and application as usual concrete. There do not still exist consistent dimensioning rules due to the lack sufficient large-scale static and dynamic experiments taking into account the effect of the fibre orientation. The intention of the book is twofold: first to summarize the most important mechanical and physical properties of steel-fibre-added concrete and reinforced concrete on the basis of numerous experiments described in the scientific literature, and second to describe a quasi-static fracture process at meso-scale both in plain concrete and fibrous concrete using a novel discrete lattice model. In 2D and 3D simulations of fibrous concrete specimens under uniaxial tension, the effect of the fibre volume, fibre distribution, fibre orientation, fibre length, fibrous bond strength and specimen size on both the stress-strain curve and fracture process was carefully analyzed.
[-] The following 8 users Like cargadory2k's post:8 users Like cargadory2k's post
  • Nilupa, Grunf, Dell_Brett, kowheng, pssst, cordoba123, oanm2000, sodapas
 ibg0203
China
User ID: 1557
Threads: 280
Likes: 6,208 in 686 posts
Given Likes: 1411
10-11-2010, 03:28 PM
mirrors
[-] The following 8 users Like ibg0203's post:8 users Like ibg0203's post
  • pssst, cordoba123, Dell_Brett, oanm2000, PanosP, chenamoy, simanta, lisine
 sodapas
Indonesia
User ID: 1004
Likes: 856 in 83 posts
Given Likes: 4073
07-04-2011, 06:00 PM
Author: Jacek Tejchman and Jan Kozicki | Size: 11.9 MB | Format: PDF | Publisher: Springer | Year: 2010 | pages: 291 | ISBN: 3642146023
[Image: 79889702279173649049.jpg]
[-] The following 12 users Like sodapas's post:12 users Like sodapas's post
  • Jackass, cigutierrezg, pedzaquino, Dell_Brett, user108, kowheng, zrilek, vvvv, oanm2000, malc, dersaar, Nilupa
Likes: 12,073 in 1,233 posts
02-04-2013, 07:09 PM
[-] The following 2 users Like pezhmankhan's post:2 users Like pezhmankhan's post
  • Dell_Brett, Nilupa
