Civil Engineering Association eBooks Codes, Manual & Handbook Eurocode (EC) SSEDTA for Eurocode 4
 Bmartin
User ID: 18368
Threads: 13
Likes: 315 in 23 posts
Given Likes: 25
09-02-2010, 04:54 PM
SSEDTA (Structural Steelwork Eurocodes Development of A Trans-national Approach) teaching material for Eurocode 4. Contains word documents and power points.
CONTENTS
1 Introduction to composite construction of buildings
2 Introduction to EC4
3 Structural modelling and design
4 Composite Slabs with Profiled Steel Sheeting
5 Shear Connectors and Structural Analysis
6 Simply supported beams
7 Continuous Beams
8 Composite Columns
9 Composite joints
10 Advanced composite floor systems
11a Introduction to Structural Fire Engineering
11b Fire Engineering Design of Composite Structures
[-] The following 14 users Like Bmartin's post:14 users Like Bmartin's post
  • hapsea, Mohoh77, jorgeramos, Dell_Brett, Grunf, kowheng, oanm2000, cristi, vvvv, zrilek, rezart, jcbv, SCREAM7890, melekeen
 Kurucz
User ID: 25975
Threads: 19
Likes: 611 in 43 posts
Given Likes: 33
09-03-2010, 10:29 AM
SSEDTA for Eurocode 3
SSEDTA for Eurocode 3.
CONTENTS
Foreword
Module 1 - Introduction to the design of structural steelwork in accordance with the new Eurocodes
1 Introduction to the new Eurocodes.
2 Introduction to Eurocode 1
3 Introduction to Eurocode 3
Module 2 - Frame analysis and design
4 Frame idealization & analysis
5 Frame classification & joint representation
Module 3 - Frame design approaches
6 Choice of frame analysis & implications for design
7 Traditional and modern design approaches
8 Practical application of modern design approaches
Module 4 - Member Design
9 Local buckling and section classification
10 Tension members
11 Restrained beams
12 Unrestrained beams
13 Columns
14 Beam-columns
Module 5 - Joints
15 Generalities about structural joints
16 Simple joints
17 The Characterisation and idealisation of moment resisting joints
18 Practical procedures for the characterisation of the response of moment resisting joints (4 files)
Module 6 - Fire Engineering Design
19 Introduction to EC3 Fire engineering design.
Module 7 - Worked examples
20 Simple braced frame
21 Comparative design of a braced non-sway frame using simple, semi-rigid and rigid joints. (courtesy of CTICM and the University of Liege)
22 Design of an unbraced sway frame with rigid joints (not included)
23 Comparative design of an unbraced sway frame using rigid and semi-rigid joints (courtesy of CTICM and the University of Liege)
24 Portal frame – elastic (courtesy of CTICM)
25 Portal frame – plastic (courtesy of the Steel Construction Institute)
[-] The following 20 users Like Kurucz's post:20 users Like Kurucz's post
  • Bmartin, jcbv, hapsea, Grunf, lamkin, cordoba123, oanm2000, ibg0203, Dell_Brett, cristi, GROUT, vvvv, zrilek, ruaumoko, rezart, allagui10, Jackass, SCREAM7890, melekeen, serhioSPA
