Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem SAP2000 v14.2.0 design results
 imran
User ID: 2251
Threads: 58
Likes: 1,028 in 65 posts
Given Likes: 133
08-24-2010, 11:26 PM
I analyzed and designed the model but the steel requirement is less in only one column. So if some one can tell me what is wrong with my model I would be greatly obliged.
The model is attached
[Image: 28101093992876287373.png]
 red_pool61
User ID: 165
Threads: 2
Likes: 522 in 61 posts
Given Likes: 319
08-25-2010, 01:23 AM
It seems, that have a some mistake in v.14.2.2.
I checked similar model according to EC 2-1992.
In the same column steel requirement is less......
Bad.....
[-] The following 1 user Likes red_pool61's post:1 user Likes red_pool61's post
  • imran
 ascetic19
User ID: 100
Threads: 23
Likes: 498 in 65 posts
Given Likes: 673
08-25-2010, 05:09 AM
i worked on model limited time
first : problem is about sap2000 mesh options. if you delete slab elements or auto mesh option,
you can get same results from column design.
i have to go out now if i find what the error is, i am gonna share with you
regards,
[-] The following 1 user Likes ascetic19's post:1 user Likes ascetic19's post
  • imran
 ascetic19
User ID: 100
Threads: 23
Given Likes: 673
08-26-2010, 11:35 AM
dear friends,
in sap 2000 14.2 or 14.2.2 ( i have no tried previous ones )
there is serious problem about meshing shell elements.
pls. be aware of this stiuation
i could not find any solution for this changing references
if you know solution for this pls. share with us
best regards,
 struceng
Russian Federation
User ID: 258
Threads: 268
Likes: 10,197 in 602 posts
Given Likes: 741
08-26-2010, 11:44 AM (This post was last modified: 08-26-2010, 11:45 AM by struceng.)
Dear Ascetic19,
Please describe the problem about meshing in detailed way.
Regards.
 imran
User ID: 2251
Threads: 58
Given Likes: 133
08-26-2010, 05:02 PM
I tried the same model in SAP2000 v12 and it was fine so i think it is only isolated to v14 and above.
struceng --> please check the model it is giving incorrect steel in columns and also giving very high steel in 2nd storey (sap2000 v12 and v14) while etabs gives steel area of arount 5 in^2 and sap gives around 9 in^2.
I detected it in such a simple model but for a complex model it would be impossible to detect
 ascetic19
User ID: 100
Threads: 23
Given Likes: 673
08-27-2010, 05:17 AM
(08-26-2010, 11:44 AM)struceng Wrote: Dear Ascetic19,
Regards.
after defining slab elements,
if you do not assign auto mesh over those slabs there is no difference
column design results,
if you do assign auto mesh over those slabs there is difference between column design results as shown imran' s posts
 struceng
Russian Federation
User ID: 258
Threads: 268
Given Likes: 741
08-29-2010, 06:09 PM (This post was last modified: 08-29-2010, 06:11 PM by struceng.)
The problem is not about meshing. It is about M2 design moment in concrete design. When M2 is negative and M3 is positive, rebar area is calculated lower than it must be except minimum reinforcement is applied (also tested for other structures). For other sign configurations of M2 and M3, there seems no problem. For Eurocode 2:2005 there seems no problem but all other codes are affected. There seems no problem in steel design.
This error is very annoying for conrete designers.
Regards.
[-] The following 6 users Like struceng's post:6 users Like struceng's post
  • imran, Dell_Brett, aslam, rudyhera03, ascetic19, Grunf
 zipatton
User ID: 1594
Threads: 4
Likes: 251 in 66 posts
Given Likes: 123
08-30-2010, 05:33 AM
Hi all,
For SAP2000 v14.2.2 and Eurocode2, the design is OK for me.
best regards
Zipat
[-] The following 1 user Likes zipatton's post:1 user Likes zipatton's post
  • Grunf
 ascetic19
User ID: 100
Threads: 23
Given Likes: 673
08-30-2010, 05:36 AM (This post was last modified: 08-30-2010, 05:45 AM by ascetic19.)
dear struceng,
this error really funny. i do not understand csi.
how can they do this kind of mistake?
best regards,
on the other hand,
i wanna say something
i removed automesh on same model,
m22 sign is negative but results are same. i think problem is not only about
m22 signs
am i right?
Users browsing this thread: 4 Guest(s)
Pages (2): 1 2 Next »
