Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Autocad Start up
Autocad Start up
 yucapareja
User ID: 8
Threads: 68
Likes: 870 in 135 posts
Given Likes: 381
Points:9,137 EP
08-21-2010, 04:42 PM
All,
I have problems with Autocad, when I started up it loaded until 44% and stops. I install and reinstal Autocad 2009 and 2010m and the same problem. I assume that is a problem with the windows (xp).
Couples months ago worked fine...:no:
Anyone have the same problem?
Thanks in Advance.
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,029 in 2,185 posts
Given Likes: 42446
Points:111,098 EP
08-22-2010, 12:14 PM
Dear Yucapareja,
Have you tried to completely uninstall any old version of AutoCAD? You can use programs like: Your Uninstaller, Revo Uninstaller, Advanced Uninstaller Pro, etc.
Also, try to clean up your registry with programs like CCleanner. There's a lot around!
Finally, if no one's results OK, try to install in SAFE MODE.
Let us know if you solve the problem...
Dell Brett
[-] The following 3 users Like Dell_Brett's post:3 users Like Dell_Brett's post
  • levanduy, yucapareja, Grunf
