Connect with your social network account
Civil Engineering Association Various Free Discussion mathematical modeling technique
 Batman07
Semi Senior Member
User ID: 22745
Threads: 51
Likes: 654 in 86 posts
Given Likes: 709
Points: 7,980 EP
08-11-2010, 04:12 AM
Hi everyone!
I just want to have a survey regarding the best way to model a flat plate/slab.
Which of the following model do you prefer to use in your analysis when having a flat slab and with varying area loads?
a. Slab defined as membrane with imaginary beam with depth equal to the depth of slab connected to the vertical elements.
b. Slab defined as shell meshed automatically to vertical elements.
c. Slab defined as shell meshed manually to column/wall.
"If I had eight hours to chop down a tree, I'd spend six sharpening my ax. "- A. Lincoln
