Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general Case History Evaluation of the Behaviour of Drilled Shafts Under Axial and Lateral Lo
 isurya
Indonesia
User ID: 1083
Threads: 39
Likes: 1,097 in 58 posts
Given Likes: 3281
08-06-2010, 03:19 PM
Case History Evaluation of the Behaviour of Drilled Shafts Under Axial and Lateral Loading
[Image: 06276824700116013684.jpg]
This report presents the results of a study to evaluate drilled shaft behavior under axial and lateral loading for undrained and drained conditions. This is a critical evaluation that incorporates a wide variety of available field and laboratory load test data, standardized to a consistent reference plane. It gives specific design recommendations for drilled shafts and the appropriate statistics to describe the quality of the recommendations.
As a result of gravity dead loads, vertical live loads such as ice and snow accumulations and lateral wind loads, the design of foundations for transmission line structures is dominated by axial and lateral loading. A variety of analytical models and load test databases have led to differences and perception of drilled shaft behavior under these loading modes and a consistent design methodology does not exist for those foundations. As a result, engineers often recommend drilled shafts having significantly different dimensions for identical geotechnical and loading conditions.
Prepared by : Cornell University
For : Electric Power Research Institute (EPRI)
Author : F.H. Kulhawy and J.C. Chen
Year : 1994
Number of pages : 398
[-] The following 20 users Like isurya's post:20 users Like isurya's post
  • OSHO, Dell_Brett, kowheng, ziggywas1, toa011, robertsas, jpver, dajabar, nhim4mat2006, cristi, shaker, ntdung, civilteam, kkteo03, theanhpe, cigutierrezg, Nilupa, utan, Evandrojr, alibouafia
12-15-2010, 05:10 AM (This post was last modified: 08-11-2012, 06:29 AM by kowheng.)
PDF|RAR 10.85|10.60 MB
[-] The following 10 users Like kowheng's post:10 users Like kowheng's post
  • usman, Grunf, redtony, cigutierrezg, Nilupa, peymanlord, shadabg, warlord1, lisine, utan
09-18-2012, 08:16 AM
[-] The following 4 users Like shadabg's post:4 users Like shadabg's post
  • malc, Evandrojr, OSHO, zrilek
  USDOT: Drilled Shafts: Construction Procedures and LRFD Design Methods isurya 4 3,877 11-22-2012, 03:46 PM
Last Post: miquan
  Calibration of Resistance Factors Needed in the LRFD Design of Drilled Shafts mahyarov 0 1,468 10-30-2012, 08:36 AM
Last Post: mahyarov
  Engineering Policy Guidelines For Design Of Drilled Shafts mahyarov 0 1,534 10-29-2012, 07:22 AM
Last Post: mahyarov
  Modeling of Pile Footings and Drilled Shafts for Seismic Design mahyarov 0 1,476 10-28-2012, 06:04 AM
Last Post: mahyarov
  Drilled Shafts In Rock: Analysis and Design abudabeeja 2 2,731 10-04-2012, 09:58 AM
Last Post: shadabg
  DRILLED SHAFTS FOR BRIDGE FOUNDATIONS OSHO 1 2,279 04-16-2012, 08:28 AM
