Civil Engineering Association eBooks Codes, Manual & Handbook CSA CSA A23.1/A23.2: Concrete Materials and Methods of Concrete Construction
 usman
User ID: 59
Threads: 138
Likes: 6,571 in 671 posts
Given Likes: 4974
07-22-2010, 04:07 PM (This post was last modified: 02-04-2013, 02:40 AM by usman.)
CSA A23.1-00 - Concrete Materials and Methods of Concrete Construction
CSA A23.2-00 - Methods of Test for Concrete
Canadian Standards Association
[Image: 39552674709473269943.gif]
  • Introduction
  • Scope
  • Definitions and Reference Publications
  • Cements and Supplementary Cementing Materials
  • Water
  • Aggregates
  • Admixtures
  • Reinforcement
  • Hardware and Miscellaneous Materials
  • Storage of Materials
  • Construction Tolerances for Cast-in-Place Concrete
  • Formwork
  • Fabrication and Placement of Reinforcement
  • Fabrication and Placement of Hardware and Other Embedded Items
  • Mix Proportions
  • Durability Requirements
  • Alternatives for Specifying Concrete
  • Concrete Quality
  • Production of Concrete
  • Placing of Concrete
  • Joints
  • Curing and Protection
  • Finishing and Treatment of Slab or Floor Surfaces
  • Toppings
  • Finishing of Formed Surfaces
  • Post-Tensioning
  • Precast Concrete in the Field
  • Architectural Concrete
  • No-Fines Concrete
  • Special Requirements for High-Strength Concretes
  • Figures
  • Appendices
[Image: 50200941184360963571.gif]
[Image: 76604505218875966921.gif]
  • Introduction
  • Scope
  • Test Methods
  • A23.2-1A Sampling Aggregates for Use in Concrete
  • A23.2-2A Sieve Analysis of Fine and Coarse Aggregate
  • A23.2-3A Clay Lumps in Natural Aggregate
  • A23.2-4A Low-Density Granular Material in Aggregate
  • A23.2-5A Amount of Material Finer than 80 µm in Aggregate
  • A23.2-6A Relative Density and Absorption of Fine Aggregate
  • A23.2-7A Test for Organic Impurities in Fine Aggregates for Concrete
  • A23.2-8A Measuring Mortar-Strength Properties of Fine Aggregate
  • A23.2-9A Soundness of Aggregate by Use of Magnesium Sulphate
  • A23.2-10A Density of Aggregate
  • A23.2-11A Surface Moisture in Fine Aggregate
  • A23.2-12A Relative Density and Absorption of Coarse Aggregate
  • A23.2-13A Flat and Elongated Particles in Coarse Aggregate
  • A23.2-14A Potential Expansivity of Aggregates (Procedure for Length Change Due to Alkali-Aggregate Reaction in Concrete Prisms)
  • A23.2-16A Resistance to Degradation of Small-Size Coarse Aggregate by Abrasion and Impact in the Los Angeles Machine
  • A23.2-17A Resistance to Degradation of Large-Size Coarse Aggregate by Abrasion and Impact in the Los Angeles Machine
  • A23.2-23A Test Method for the Resistance of Fine Aggregate to Degradation by Abrasion in the Micro-Deval Apparatus
  • A23.2-24A Test Method for Resistance of Unconfined Coarse Aggregate to Freezing and Thawing
  • A23.2-25A Test Method for Detection of Alkali-Silica Reactive Aggregate by Accelerated Expansion of Mortar Bars
  • A23.2-26A Determination of Potential Alkali-Carbonate Reactivity of Quarried Carbonate Rocks by Chemical Composition
  • A23.2-27A Standard Practice to Identify Degree of Alkali-Reactivity of Aggregates and to Identify Measures to Avoid Deleterious Expansion in Concrete
  • A23.2-28A Standard Practice for Laboratory Testing to Demonstrate the Effectiveness of Supplementary Cementing Materials and Chemical Admixtures to Prevent Alkali-Silica Reaction in Concrete
  • A23.2-29A Test Method for the Resistance of Coarse Aggregate to Degradation by Abrasion in the Micro-Deval Apparatus
  • A23.2-1B Viscosity, Bleeding, Expansion, and Compressive Strength of Flowable Grout
  • A23.2-2B Determination of Sulphate Ion Content in Groundwater
  • A23.2-3B Determination of Total or Water-Soluble Sulphate Ion Content of Soil
  • A23.2-4B Sampling and Determination of Water-Soluble Chloride Ion Content in Hardened Grout or Concrete
  • A23.2-6B Method of Test to Determine Adhesion by Tensile Load
  • A23.2-7B Random Sampling of Construction Materials
  • A23.2-1C Sampling Plastic Concrete
  • A23.2-2C Making Concrete Mixes in the Laboratory
  • A23.2-3C Making and Curing Concrete Compression and Flexural Test Specimens
  • A23.2-4C Air Content of Plastic Concrete by the Pressure Method
  • A23.2-5C Slump of Concrete
  • A23.2-6C Density, Yield, and Cementing Materials Factor of Plastic Concrete
  • A23.2-7C Air Content of Plastic Concrete by the Volumetric Method
  • A23.2-8C Flexural Strength of Concrete (Using Simple Beam with Third-Point Loading)
  • A23.2-9C Compressive Strength of Cylindrical Concrete Specimens
  • A23.2-10C Accelerating the Curing of Concrete Cylinders and Determining Their Compressive Strength
  • A23.2-11C Water Absorption of Concrete
  • A23.2-12C Making, Curing, and Testing Compression Test Specimens of No-Slump Concrete
  • A23.2-13C Splitting Tensile Strength of Cylindrical Concrete Specimens
  • A23.2-14C Obtaining and Testing Drilled Cores for Compressive Strength Testing
  • A23.2-1D Moulds for Forming Concrete Test Cylinders Vertically
  • Appendices
  • A — Nondestructive Methods for Testing Concrete
  • B — Form for Reporting Compressive Strength of Concrete Test Cylinders
[Image: 68117334243150934398.gif]
[Image: 06440903556161325511.gif]
The Canadian Standards Association web page:
[-] The following 13 users Like usman's post:13 users Like usman's post
  • kowheng, arceon, hzaheer, civilteam, super_engineer, Dell_Brett, saed, robertsas, pezhmankhan, blaze, Grunf, zinousoft, sivlad
01-08-2011, 02:54 PM (This post was last modified: 02-04-2013, 02:41 AM by usman.)
Uploaded: Jan/08/2011, File Size: 1.17 MB, RAR'd single PDF (paginated, bookmarked, searchable text)
[-] The following 9 users Like Grunf's post:9 users Like Grunf's post
  • vardan, oanm2000, usman, Dell_Brett, mrjoesan2, zinousoft, adi04, sivlad, Jackass
 usman
User ID: 59
Threads: 138
Given Likes: 4974
02-02-2013, 06:19 PM (This post was last modified: 02-04-2013, 02:40 AM by usman.)
[-] The following 5 users Like usman's post:5 users Like usman's post
  • ir_71, Grunf, malc, Dell_Brett, Jackass
 usman
User ID: 59
Threads: 138
Given Likes: 4974
02-04-2013, 02:36 AM (This post was last modified: 02-04-2013, 02:38 AM by usman.)
CSA A23.1-04 - Concrete Materials and Methods of Concrete Construction
CSA A23.2-04 - Methods of Test and Standard Practices for Concrete
Size: 39+57 MB | Format: PDF | Quality: Scanner | Publisher: CSA | Year: 2004 | pages: 201+321 | ISBN: 1-55397-662-2
[Image: 26021255199136602664.jpg]
  • malc, kowheng, Dell_Brett, blaze, Jackass
 usman
User ID: 59
Threads: 138
Given Likes: 4974
02-06-2013, 01:14 AM
CSA A23.1-09 - Concrete Materials and Methods of Concrete Construction
CSA A23.2-09 - Test Methods and Standard Practices for Concrete
Size: 17 MB | Format: PDF | Quality: Unspecified | Publisher: CSA | Year: 2009 | pages: 658 | ISBN: 978-1-55491-273-5
[Image: 63735911793160061030.jpg]
[-] The following 12 users Like usman's post:12 users Like usman's post
  • malc, gulilero, kowheng, blaze, p_vosoughi, Jackass, ibg0203, ir_71, Grunf, knrsa, pezhmankhan, toa011
Likes: 8,200 in 1,338 posts
05-01-2024, 07:51 AM (This post was last modified: 05-01-2024, 07:52 AM by poolmand.)
CSA A23.1-14 - Concrete Materials and Methods of Concrete Construction
CSA A23.2-14 - Test Methods and Standard Practices for Concrete
[Image: 72499040294025320335.png]
  • civilfafa, PinkPant, babakfeyzi, lisine
07-21-2024, 09:20 AM
CSA A23.1:24/CSA A23.2:24 Concrete materials and methods of concrete construction/Test Methods and Standard Practices for concrete
| Size: 82.6 MB| Format: PDF| Quality: Original preprint| Year: 2024
  • babakfeyzi, PinkPant
 whysx
User ID: 2025
Threads: 24
Likes: 22 in 11 posts
Given Likes: 0
07-23-2024, 12:50 AM
would you please give mediafire download?
07-23-2024, 03:31 AM (This post was last modified: 07-23-2024, 03:33 AM by poolmand.)
  • PinkPant, babakfeyzi
  [CivilEA Exclusive] CSA W186: Welding of reinforcing bars in reinforced concrete construction poolmand 0 2,589 05-07-2024, 09:33 AM
  CSA A438-M84 - Concrete Construction for Housing and Small Buildings usman 0 1,765 07-23-2010, 03:52 AM
Last Post: usman
