Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive Computation of Secondary Moments in Prestressed Concrete Structures
 quatermain
User ID: 21366
Threads: 64
Likes: 23 in 19 posts
Given Likes: 113
07-14-2010, 01:05 PM
Hi, Maybe someone got this paper for me.
ABSTRACT
Venketaramani Tiruchirapalli1 and Riyadh Hindi,2 Ph.D., P.Eng.
1Graduate Student, Bradley University, Peoria, Illinois,
2Associate professor, Bradley University, Peoria, Illinois,
The consideration and computation of secondary moments are important in the design analysis of continuous prestressed concrete structures. Such moments are secondary in nature but not in magnitude. Based on a comprehensive review of available methods of computing secondary moments such as equivalent load method, an alternative methodology of computing secondary moments is developed in this study. The proposed method discretizes an indeterminate structure into individual structural elements with end constrains. The concept of secondary moments under constraints is introduced in discrete structural elements. And they are computed as the function of primary moments in the structure. Secondary moments in the structure are then computed by applying basic principles in structural mechanics. The computing procedure is shown to be simple, prompt and accurate. The advantages of the proposed method over other existing methods are discussed and illustrated through numerical examples. In addition, the proposed computing method can be readily integrated into existing finite element codes of structural modeling and design. The application of the proposed method in practical design practice is demonstrated through a design case with complex tendon geometry.
Thanks
 deviationz
User ID: 2031
Threads: 51
Likes: 546 in 107 posts
Given Likes: 72
07-14-2010, 01:19 PM (This post was last modified: 07-14-2010, 04:38 PM by Dell_Brett.)
I have a different paper that addresses secondary moments in PT construction.
[-] The following 1 user Likes deviationz's post:1 user Likes deviationz's post
  • quatermain
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Likes: 7,707 in 755 posts
Given Likes: 2168
07-14-2010, 02:19 PM
@ Deviationz,
Link is not proper
 unix0123
User ID: 14411
Threads: 1
Likes: 99 in 15 posts
Given Likes: 55
07-14-2010, 03:39 PM
Here is the correct link
[-] The following 9 users Like unix0123's post:9 users Like unix0123's post
  • Dell_Brett, cesar3226, ruaumoko, axcel, quatermain, jf28, Aiyub, pousin, viet2010
 quatermain
User ID: 21366
Threads: 64
Given Likes: 113
07-15-2010, 04:08 AM
Thank you all.
In addition any other papers regarding secondary prestress effects will be appreciated.
  [REQUEST] Design and Typical Details of Connections for Precast and Prestressed Concrete mulham lee 2 4,283 01-02-2022, 06:43 AM
Last Post: pezhmankhan
  [REQUEST] Design of Prestressed Concrete to Eurocode 2, Second Edition camto2 2 3,538 12-05-2019, 04:48 AM
  [REQUEST] Seismic Design of Precast/Prestressed Concrete Structures aslam 1 2,527 06-06-2019, 03:45 PM
Last Post: temp1366
  [REQUEST] Design of Prestressed Concrete to AS3600-2009, 2nd Ed by Gilbert, Mickleborou & Ranzi rohailiyaz 2 2,129 02-23-2016, 01:51 PM
Last Post: rohailiyaz
  Designing for earthquake using precast/prestressed concrete by Ned Cleland,S.K.Ghosh aslam 2 2,688 12-14-2014, 06:30 PM
Last Post: gulilero
  Reinforced and Prestressed Concrete Design to EC2 mantas1985 1 2,872 10-29-2014, 04:24 PM
Last Post: Immelmann
  [REQUEST] Precast Prestressed Concrete Bridge Design Manual Third Edition peixoto 1 2,653 05-11-2014, 06:03 PM
Last Post: arshiakh
