Civil Engineering Association eBooks Structural Books Other Materials (Wood, Brick, etc.) Modeling of Masonry Infill Panels for Structural Analysis
 E123
User ID: 21746
Threads: 32
Likes: 605 in 39 posts
Given Likes: 8
06-11-2010, 05:39 PM (This post was last modified: 06-12-2010, 01:25 PM by Grunf.)
[Image: 60906712501739367368.jpg]
A.M. Reinhorn, A. Madan, R.E. Valles, Y. Reichmann and J.B.Mander
NCEER-95-0018 | 12/8/1995 | 96 pages |
A smooth hysteretic model based on an equivalent strut approach is proposed for masonry infill panels to be used in nonlinear analysis of building structures. The hysteretic model furnishes a versatile and robust simulation tool for representing masonry infill panels. The model, which is applicable for degrading ‘pinching’ elements in general, can be implemented to replicate a wide range of hysteretic force-displacement behavior resulting from different design and geometry by varying the control parameters of the model. The control parameters of the proposed hysteretic model can be determined using any suitable theoretical model for masonry infills. The report presents the development of the proposed hysteretic model. An available theoretical model for masonry infilled frames is recommended for estimating the control parameters of the proposed hysteretic rule. The methodology for calibrating the hysteretic model parameters is described. The hysteretic model is incorporated in the structural analysis program, IDARC2D Version 4.0, for quasi-static cyclic and dynamic analysis of masonry infilled frames. Simulations of experimental force-deformation behavior of prototype infill frame subassemblages are performed to validate the proposed model and presented herein. A lightly reinforced concrete frame structure is analyzed for strong ground motions to evaluate the influence of masonry infill panels on the response.
[-] The following 13 users Like E123's post:13 users Like E123's post
  • cristi, Dell_Brett, kowheng, faros3000, chenamoy, RANA WASEEM, moh_towhid, maad59, abouferass88, Ultra Zone, ambrish, Sumatra, simanta
 Badis
Senior Member
User ID: 16671
Threads: 54
Likes: 2,308 in 169 posts
Given Likes: 220
06-13-2010, 01:47 AM
Mirror links:
[-] The following 12 users Like Badis's post:12 users Like Badis's post
  • yantonegr, Grunf, Dell_Brett, GROUT, tibas, jcoronellr, zrilek, Sumatra, kowheng, sipil, arceon, oscargon
  Structural Masonry 2nd edition sabooryan 0 2,739 01-15-2021, 09:36 AM
Last Post: sabooryan
  Structural Performance of Masonry Elements: Mortar Coating Layers Influence carolinandra 0 1,480 01-16-2019, 06:13 PM
Last Post: carolinandra
  Design of Structural Masonry babak 4 4,161 02-24-2018, 06:19 PM
  Structural Masonry Designers’ Manual abudabeeja 4 4,251 04-29-2013, 02:23 PM
  MASONRY STRUCTURAL DESIGN FOR BUILDINGS tuanpecc1 1 2,616 09-06-2012, 06:37 AM
Last Post: shadabg
  USACoE: Tri Directional Seismic Analysis of an Unreinforce Masonry Building Veggeta 1 3,080 01-18-2011, 10:07 AM
