Civil Engineering Association eBooks Codes, Manual & Handbook API RP 2A: RP for Planning, Designing & Constructing Fixed Offshore Platforms
 labqIM
User ID: 19937
Threads: 5
Likes: 40 in 9 posts
Given Likes: 37
06-01-2010, 11:34 AM (This post was last modified: 12-29-2011, 11:00 PM by usman.)
API RP 2A WSD 00 - Planning, Designing and Constructing Fixed Offshore Platforms
API RECOMMENDED PRACTICE 2A-WSD (RP 2A-WSD) TWENTY-FIRST EDITION, DECEMBER 2000
This Recommended Practice for Planning, Designing, and Constructing Fixed Offshore Platforms contains engineering design principles and good practices that have evolved during the development of offshore oil resources.
[-] The following 9 users Like labqIM's post:9 users Like labqIM's post
  • highcivil, Dell_Brett, jacs127, saed, ravisbassi, zrilek, oanm2000, joy2000, blaze
 labqIM
User ID: 19937
Threads: 5
Given Likes: 37
06-03-2010, 03:08 AM
here's the mirror link
[-] The following 6 users Like labqIM's post:6 users Like labqIM's post
  • kowheng, robertsas, Dell_Brett, lednar_ved, zrilek, oanm2000
 labqIM
User ID: 19937
Threads: 5
Given Likes: 37
09-06-2010, 07:01 AM (This post was last modified: 12-29-2011, 10:55 PM by usman.)
API RP 2A-LRFD RP for Planning, Designing & Constructing Fixed Offshore Platforms - Load and Resistance Factor Design
[Image: 65746214458172135730.png]
Recommended Practice for Planning, Designing and Constructing Fixed Offshore Platforms - Load and Resistance Factor Design
API RP 2A-LRFD
First Edition, July 1, 1993
  • robertsas, oanm2000, Ultra Zone, kowheng, blaze, anfaga
 toa011
User ID: 9336
Threads: 135
Likes: 6,122 in 224 posts
Given Likes: 3356
09-14-2010, 01:41 PM
It is important to information provided on this document is as accurate as possible. Please check
and
. API RP 2A-LRFD is sitll very current even though API/RP-2A_WSD is more up-to-date. You should have the choice of whatever method to use, with experience and good engineering judgment.
[-] The following 4 users Like toa011's post:4 users Like toa011's post
  • oanm2000, Dell_Brett, arturom, sujups
 jacs127
Senior Member
Banned
User ID: 11255
Threads: 125
Likes: 1,667 in 225 posts
Given Likes: 605
03-04-2011, 09:51 AM
Dear friends here i find the recent version.
[-] The following 12 users Like jacs127's post:12 users Like jacs127's post
  • Dell_Brett, kowheng, ir_71, labqIM, blaze, Adam Smith, zrilek, rezart, oanm2000, ELAHI1979, monter, chrono146
03-24-2011, 09:14 PM (This post was last modified: 03-25-2011, 03:24 AM by usman.)
API RECOMMENDED PRACTICE 2A-WSD (RP 2A-WSD) Recommended Practice for Planning, Designing and Constructing Fixed Offshore Platforms—Working Stress Design
Size: 5.3 MB | Format: PDF | Publisher: APi | Year: 2007 | pages: 288
[Image: 41995613577499564088.jpg]
This Recommended Practice for Planning, Designing, and Constructing Fixed Offshore Platforms contains engineering design principles and good practices that have evolved during the development of offshore oil resources. Good practice is based on good engineering; therefore, this recommended practice consists essentially of good engineering recommendations. In no case is any specific recommendation included which could not be accomplished by presently available techniques and equipment. Consideration is given in all cases to the safety of personnel, compliance with existing regulations, and antipollution of water bodies. Metric conversions of customary English units are provided throughout the text of this publication in parentheses, e.g., 6 in. (152 mm). Most of the converted values have been rounded for most practical usefulness; however, precise conversions have been used where safety and technical considerations dictate. In case of dispute, the customary English values should govern. Offshore technology is growing rapidly. In those areas where the committee felt that adequate data were available, specific and detailed recommendations are given. In other areas general statements are used to indicate that consideration should be given to those particular points. Designers are encouraged to utilize all research advances available to them. As offshore knowledge continues to grow, this recommended practice will be revised. It is hoped that the general statements contained herein will gradually be replaced by detailed recommendations. Reference in this practice is made to the latest edition of the AISC Specification for the Design, Fabrication and Erection of Structural Steel for Buildings (see Section 2.5.1a). While the use of latest edition of this specification is still endorsed, the use of the new AISC Load & Resistance Factor Design (LRFD), First Edition is specifically not recommended for design of offshore platforms. The load and resistance factors in this new code are based on calibration with building design practices and are therefore not applicable to offshore platforms. Research work is now in progress to incorporate the strength provisions of the new AISC LRFD code into offshore design practices. In this practice, reference is made to ANSI/AWS D1.1-2002 Structural Welding Code—Steel. While use of this edition is endorsed, the primary intent is that the AWS code be followed for the welding and fabrication of Fixed Offshore Platforms. Chapters 8, 9, and 10 of the AWS Code give guidance that may be relevant to the design of Fixed Offshore Platforms. This Recommended Practice makes specific reference to Chapter 9 and 10 for certain design considerations. Where specific guidance is given in this API document, as in Sections 4 and 5, this guidance should take precedence. This standard shall become effective on the date printed on the cover but may be used voluntarily from the date of distribution.
  • usman, kowheng, zrilek, malc, isurya, seriousboy, rendel_©, sivlad, strengr, oanm2000
 f_slikken
User ID: 21091
Threads: 13
Likes: 910 in 88 posts
Given Likes: 778
03-14-2015, 11:01 PM
All,
The first edi:
And the 21th edi:
[-] The following 12 users Like f_slikken's post:12 users Like f_slikken's post
  • gulilero, Dell_Brett, malc, balimela, oanm2000, slowet, PinkPant, Jackass, Aviator, avge, Andrew seah, hodzicemir
 scudelari
Brazil
User ID: 58172
Threads: 0
Likes: 6 in 2 posts
Given Likes: 5
05-10-2017, 03:38 PM
Hello Everyone,
Could anyone please share the latest version of this document?
Thanks!
  API RP 2L: RP for Planning, Designing, and Constructing Heliports for Fixed Offshore ir_71 0 1,859 01-01-2011, 09:05 PM
