BS EN 10147:2000
Continuously hot-dip zinc coated structural steels strip and sheet. Technical delivery conditions
Status : Superseded, Withdrawn Published : July 2000
![[Image: info.png]](https://forum.civilea.com/postgen/info.png)
Standard Number: BS EN 10147:2000
Publication Date: 15 July 2000
Withdrawn Date: 14 July 2004
Cross References: EN 10142, EN 10152, EN 10169-1, ENV 10169-2, EN 10292, EN 10002-1, EN 10020, EN 10021, EN 10027-1, EN 10027-2, EN 10079, EN 10143, EN 10204, CR 10260, EURONORM 12
Replaced By: BS EN 10326:2004
Replaces: BS EN 10147:1992
International Relationships: EN 10147:2000 Identical
Supersedes Draft: 98/700092 DC
Descriptors: Structural steels, Strips, Sheet materials, Zinc, Metal coatings, Coatings, Hot-dip coating, Dip coating, Hot-dip galvanizing, Delivery, Flat (shape), Thickness, Steels, Width, Mass, Finishes, Surfaces, Yield strength, Corrosion resistance
ICS: 77.140.50 (Flat steel products and semi-products)
Title in French: Bandes et toles en aciers de construction galvanisees a chaud en continu. Conditions techniques de livraison
Title in German Kontinuierlich Feuerverzinktes Band und Blech aus Baustaehlen. Technische Liefervedingungen
Committee ISE/109
ISBN: 0580347931
Publisher: BSI
Format: A4
Pages: 24
![[Image: Download.png]](https://forum.civilea.com/postgen/Download.png)
***************************************Moderator note:
Moved from the Request section and redesigned
