Civil Engineering Association eBooks Codes, Manual & Handbook IEC 60826 - Design Criteria of Overhead Transmission Lines
 joanrey
User ID: 6533
Threads: 3
Likes: 16 in 2 posts
Given Likes: 21
04-22-2010, 03:40 PM (This post was last modified: 04-16-2011, 03:49 AM by usman.)
[Image: 70379160978633230670.jpg]
This International Standard specifies the loading and strength requirements of overhead lines derived from reliability based design principles. These requirements apply to lines 45 kV and above, but can also be applied to lines with a lower nominal voltage.
:clap: been some time looking for this... found it and now sharing it.
This standard also provides a framework for the preparation of national standards dealing with overhead transmission lines, using reliability concepts and employing probabilistic or semi-probabilistic methods. These national standards will need to establish the local climatic data for the use and application of this standard, in addition to other data that are country specific.
Although the design criteria in this standard apply to new lines, many concepts can be used to address the reliability requirements for refurbishment and uprating of existing lines.
This standard does not cover the detailed design of line components such as towers, foundations, conductors or insulators.
[-] The following 13 users Like joanrey's post:13 users Like joanrey's post
  • kowheng, super_engineer, pezhmankhan, salahcivil, maznunu, usman, Dell_Brett, avscorreia, concreteok, jcbv, oanm2000, TAFATNEB, sivlad
04-16-2011, 05:19 AM
New links:
  • malc, blaze, concreteok, jcbv, knrsa, ruaumoko, shaker, oanm2000, Grunf, zrilek, mahfuzbangla, sivlad, louislouis, crichs
04-09-2018, 06:15 PM
IEC 60826-2017 Overhead transmission lines - Design criteria
Author(s)/Editor(s): Electrotechnical Commission (IEC) | Size: 2.5 MB | Format: PDF | Quality: Original preprint | Publisher: Electrotechnical Commission (IEC) | Year: 2017 | pages: 79 | ISBN: 9782832238844
[Image: 39939573864514356781.jpg]
This International Standard specifies the loading and strength requirements of overhead lines derived from reliability-based design principles. These requirements apply to lines 45 kV and above, but can also be applied to lines with a lower nominal voltage.
This document also provides a framework for the preparation of national standards dealing with overhead transmission lines, using reliability concepts and employing probabilistic or semi-probabilistic methods. These national standards will need to establish the local climatic data for the use and application of this standard, in addition to other data that are countryspecific.
Although the design criteria in this standard apply to new lines, many concepts can be used to address the design and reliability requirements for refurbishment, upgrading and uprating of existing lines.
This document does not cover the detailed design of line components such as supports, foundations, conductors or insulators strings.
  • jcbv, blaze, caifan, apocalipse, oanm2000, zrilek, PinkPant, Umer.Aleem, monter, shaker, subin91, munycamsec, Dell_Brett, GMianG
 apocalipse
Portugal
User ID: 41527
Threads: 105
Likes: 790 in 87 posts
Given Likes: 922
10-06-2021, 09:23 AM
Dear members,
The previous links are all dead, i would appreciate a new upload.
Thanks
10-06-2021, 10:08 AM
[-] The following 11 users Like poolmand's post:11 users Like poolmand's post
  • Administrator , jcbv, Dell_Brett, apocalipse, cace-01, usman, pedzaquino, zrilek, rami1976, PinkPant, oanm2000
  [CivilEA Exclusive] IEEE 2954: IEEE Recommended Practice For Overhead Transmission Line Design poolmand 0 2,917 06-18-2024, 06:55 AM
  ATC 32-Improved Seismic Design Criteria for California Bridges pezhmankhan 1 1,886 11-10-2021, 02:44 PM
Last Post: atram
  [REQUEST] Trial-Use Design Guide for Wood Transmission Structures civilfafa 0 1,538 12-08-2019, 07:54 AM
Last Post: civilfafa
  Transmission Line Design Code (IS 802) NAUTILUS87 2 2,878 12-31-2012, 08:06 AM
Last Post: engebrahim
  Construction Manual for Overhead Transmission Lines and Substations NAUTILUS87 1 3,119 12-04-2011, 12:37 PM
Last Post: Dell_Brett
