04-16-2009, 04:55 AM
Please Can anybody guide How can one do Lateral Analysis of building structures as per code UBC 97 including Building Frame System, Moment Resisting System and Dual System.:exclamation:
Y@sir
Y@sir
04-19-2009, 04:44 PM
Yasir, define your load as "quake" and input the UBC97 code as your preference for ETABS to determine the seismic loads. Check the seismic load output of ETABS against what you are expecting. You can also put in your manually calculated floor shears based on UBC97 unto your rigid floor diaphragms.
regards, juice
04-20-2009, 04:08 AM
I found these PowerPoint slides on the net . It was great help for me. It gives a step-by-step Dynamic Analysis of Earthquake as per UBC97 in ETABS.
![]() • Yasir, Yasir, Floms, Floms, oanm2000, oanm2000, caleno, caleno, aslam, aslam, amirdana, amirdana, huan_maivn, huan_maivn, yecky, yecky, KHIEMHAO, KHIEMHAO, orio777, orio777, lucky_b2me, lucky_b2me, rendel_©, rendel_©, ruaumoko, ruaumoko, Nedian, Nedian, timosi™, timosi™, theanhpe, jcoronellr, falconado, gini7998, Thanhtung, rama_d,
04-20-2009, 05:58 AM
How can I apply building frame system ... i.e. How can all the Lateral forces be forced to taken by shear wall only
Y@sir
04-20-2009, 06:46 AM
05-12-2009, 06:54 PM
more information?
05-12-2009, 11:17 PM
05-18-2009, 03:32 AM
(04-20-2009, 05:58 AM)Yasir Wrote: How can I apply building frame system ... i.e. How can all the Lateral forces be forced to taken by shear wall only I think, it is better to make two models. In 1st model you give pins at both column ends, so all eq load be taken by shear wall and do shearwall design. In 2nd model you design beams and columns according gravity load only, but you should confined reinforcement in the column to avoid prior shear failure (please refer to ACI318M-08 chapter 21). :)
06-07-2009, 08:28 AM
hi
Investigation of behaviors of vertical R.C walls in multistoried (metal steel) buildings. plz help
06-07-2009, 10:45 PM
