Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive STRENGTHENING OF RC BEAMS USING STEEL PLATES
 knrsa
Semi Senior Member
Banned
User ID: 82
Threads: 42
Likes: 465 in 52 posts
Given Likes: 2171
04-13-2010, 07:05 PM
Hi All
I am looking for strengthening of RC beams by adding steel plates both in flexure and shear.
If any one of you has any material / articles / design procedures for this please upload.
Thanks in advance
 faros3000
Senior Member
User ID: 61
Threads: 24
Likes: 1,265 in 175 posts
Given Likes: 1793
05-01-2010, 01:36 AM
Dear friend,
I wanted to post for you this papers before, but have been pretty bussy during the last weeks. Anyway, I hope am not too late and you still will find them useful.
I have succesfully retrofitted a couple of buildings using steel plates for RC beams, with plates in upper/bottom faces, and also with side-plated beams. I have not relied only upon epoxy adhesives, so used also epoxy fixed-metal anchors for the plates. Bear in mind that tipically steel plates are heavy, and applying adhesive to the plate and adhering it to the beam will by no means be an easy task. Also, I would advise not to use expansion anchors (if you are using anchors at all), as you will be using several of them and the expansive ones will induce a lot of internal stresses in an extensive area or, worst, create a failure plane (I have seen that).
Additional comments: steel is heavy by nature, so reinforcing an RC-beam with steel plates may also add a big load to the already over-stressed element to be reinforced. Why don´t you better try FRP wraps or laminates?
Hope this helps!
[Image: 36448144911709497581.jpg]
[Image: 57428523060173395440.jpg]
[Image: 88089868974905076541.jpg]
[Image: 26817703867311298511.jpg]
[Image: 57092857073407294571.jpg]
Information is not knowledge.
Albert Einstein
[-] The following 10 users Like faros3000's post:10 users Like faros3000's post
  • kowheng, pingfan2, rohailiyaz, knrsa, rcnet, Panjack39, oanm2000, joanrey, rohitksoni, essenza
  [REQUEST] Strengthening of concrete beams by external prestressing kuri 0 1,367 11-09-2014, 08:19 AM
Last Post: kuri
  [REQUEST] Beams, Plates and Shells ssobhan 0 1,396 04-29-2013, 10:35 AM
Last Post: ssobhan
  [REQUEST] ASCE - Guidelines for Design of Joints btw Steel Beams and Reinf Conc Columns hamzeaziz 3 2,799 12-22-2011, 04:21 PM
Last Post: mybest
  [REQUEST] Design of steel I-beams curved in-plan to BS5950 muralihare 0 1,528 08-25-2011, 04:57 PM
Last Post: muralihare
  [REQUEST] steel fiber concrete beams - ACI SJ and mater.struct. dotrun 0 1,388 03-25-2011, 06:46 AM
Last Post: dotrun
  [REQUEST] Local Web Buckling Strength of Coped Steel I Beams yucapareja 1 1,829 11-11-2010, 04:02 PM
Last Post: parhyang
