Civil Engineering Association Software Software Product Autodesk Products AutoCad LT 2027
AutoCad LT 2027
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1405
04-14-2026, 06:51 PM (This post was last modified: 04-14-2026, 06:52 PM by rami1976.)
AutocadLT2027
[Image: do.php?img=28]
AutoCAD LT 2027, released on March 25, 2026, introduces several AI-powered and cloud-connected features designed to streamline 2D drafting and collaboration.
Key New Features
-Geometry Cleanup: A new tool that automatically scans drawings to identify common errors like gaps, overshoots, undershoots, and misaligned angles.
-Autodesk Assistant (Tech Preview): Now enhanced with AI-powered chat and prompt-driven workflows. You can use natural language prompts to check your drawings against specific CAD standards by uploading a reference file.
-Checkout for Parallel Editing: This collaborative tool allows team members to work on the same DWG file simultaneously.
-Forma Data Management Essentials: Now included with standalone subscriptions, providing a centralized cloud environment for project storage, version history, and folder-level permissions.
Workflow & Collaboration Enhancements
Connected References: Automatically detects moved or renamed external references (Xrefs) in cloud-stored projects and suggests repairs from the Xref palette.
Connected Support Files: Centralizes control over cloud-managed support files. Tool Palettes and CUIx (Partial Customization) files now load automatically based on the specific project you are working on in Forma Data Management.
Layout Tab Switching: Performance improvements have noticeably reduced the time it takes to switch between layout tabs in complex drawings.
Retired & Removed Features
To support the shift to modern cloud workflows, several legacy features have been removed:
AutoCAD Web & Mobile Support: Commands like OPENFROMWEBMOBILE and SAVETOWEBMOBILE are retired.
Shared Views: Replaced by Forma Data Management for sharing and collaboration.
MrSID Support: Image files in the MrSID format can no longer be attached.
PostScript Export: The PSOUT command has been removed
👉 CLICK HERE 👈
👉 CLICK HERE 👈
[-] The following 1 user Likes rami1976's post:1 user Likes rami1976's post
  â€¢ Walker
  AUTOCAD 2027 rami1976 0 1,879 02-26-2026, 12:04 AM
